RossFI215 Posted September 22, 2008 Report Posted September 22, 2008 ok guys, im confused with this, if anyone can help it would be nice, ok heres what i got so far, my headunit has 2 rca outputs, i have 3 amp, 2 of them are spl amps which are sync together, so i have 2 rca runnin to the cd player, ok thats good and all but now im about to install 2 more amps so i'll have 4 rca's runnin to the cd player so how to i hook them up when the headunit only has 2 outputs, is there any kind of splinter thing i could use or something, help please
BackYardSoundZ Posted September 22, 2008 Report Posted September 22, 2008 Get some splitters or use the amps outputs
ALPINE408 Posted September 22, 2008 Report Posted September 22, 2008 Rca Y adapters some type of eq ór line driver with multi outputs ór maxx link Have you ever had your woofers blown?
RossFI215 Posted September 22, 2008 Author Report Posted September 22, 2008 ok i know i posted this in the wrong section my bad, i just realize it, ok so spitters would work, cuz i already have around 12,000 watts runnin in my vehicle, with 2 alts, and 3 kinetik 2400 batterys, see i was goin to put some more mids and high in there and i was really gettin confused on the rca's, its like i can figure all the other shit out but something simple i have trouble, any more idea's
ALPINE408 Posted September 22, 2008 Report Posted September 22, 2008 Thats all you can do line driver/maxx link Or eq are the best bet Ive ran 5 amps off onè rca output befor with just spliters (not for èvery day use) Have you ever had your woofers blown?
ALPINE408 Posted September 22, 2008 Report Posted September 22, 2008 Or a new hu Have you ever had your woofers blown?
RossFI215 Posted September 22, 2008 Author Report Posted September 22, 2008 but how does the spliters work and whats a line driver/maxx link, and i've looked at the eq's like the rockford fosgate 3sixty, would that work
RossFI215 Posted September 22, 2008 Author Report Posted September 22, 2008 well i just bought this new pioneer headunit, which has 2 outputs
uhoh_45 Posted September 22, 2008 Report Posted September 22, 2008 you could make your own rca splitter aswell instead of buyin a shit load of y splitters all you need to do is go to like the source or radioshack or wherever you can buy electronic stuff and buy rca plugs then wire them to eachother so front left on one side front right on the other and so on thats mine i made it for the amps its relitivly simple and cost only 12 $ and i can run 4 amps off it no problem R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
