MXmike800 Posted September 23, 2008 Report Posted September 23, 2008 looking to buy a DC lv5 15" rusty told me 1500 - 2500 RMS. im looking for an amp that will power this efficiently without underpowering it. i know most brands over rate their amps. so im looking to see what you guys have to say have a guy selling a crunch 1500D for 150$$ i can get brand new for 164$$ on ebay w/1 yr i have read hifonics and crunch makers the amps are not clean power so im worried about clipping on the dc and dont want to damage it. i am looking to spend 250 300 on an amp for now. here is a post of what i was looking at i can get it for $200 should i even bother or not? http://chicago.craigslist.org/sox/ele/849487042.html any suggestions are welcome thanks mike
EricM9104 Posted September 23, 2008 Report Posted September 23, 2008 The GP1500D does NOWHERE NEAR 1500w rms. Go for the BXi2006D. 2015 Honda Civic LX 4dr | 110k miles | Stock 1996 GMC Yukon SLT 4dr 4wd | 260k miles | JVC Head-unit
MXmike800 Posted September 23, 2008 Author Report Posted September 23, 2008 so would that be ok to run on a dc lv5 15?
benz280se Posted September 23, 2008 Report Posted September 23, 2008 looking to buy a DC lv5 15" rusty told me 1500 - 2500 RMS. im looking for an amp that will power this efficiently without underpowering it. i know most brands over rate their amps. so im looking to see what you guys have to sayhave a guy selling a crunch 1500D for 150$$ i can get brand new for 164$$ on ebay w/1 yr i have read hifonics and crunch makers the amps are not clean power so im worried about clipping on the dc and dont want to damage it. i am looking to spend 250 300 on an amp for now. here is a post of what i was looking at i can get it for $200 should i even bother or not? http://chicago.craigslist.org/sox/ele/849487042.html any suggestions are welcome thanks mike AQ1200D Frequency Response 20Hz—250Hz Signal to Noise Ratio 100db Low Pass Crossover 24db / Oct Low Pass Crossover Range 20Hz—200Hz Subsonic Crossover Range 10Hz—50Hz Input Sensitivity 0.2V—8V Output Master / Input Slave Connection Yes Working Voltage 8V---16V Efficiency @ 4 ohm 84% Damping Factor Less than 150 Fuse Rating 40Amp X 3 (Linked 240 Amp) Output Power 14.4V @ 1% THD 510X1 @ 4 ohm, 870X1 @ 2 ohm, 1200X1 @1 ohm Output Power 14.4V @ 5% THD 1470X1 @ 1 ohm Dash Mounted Remote Included Dimensions 12.75"(L)x9.27"(W)x2.35"(H) 289 plus shipping!!!
Frozenbritches Posted September 23, 2008 Report Posted September 23, 2008 Always better to go with more power and keep your gains low!!!..that's the best way to not push your amps too hard is to get one that will power it perfectly on low settings..get the 2608D hifonics...I'm using it right now so yeah it's doing quite well..best amp for the money if you ask me 2002 Jeep Grand Cherokee Laredo Hifonics Brutus Bxi2607D (FRIED...saving for ZX2500.1) 2 15" 07 L7's ported at 32hz Xplod POS for the MIDS, which are Memphis
