Same as what you are trying to use. Just use some bolts, drill some holes the same size, seal them up, and some ring terminals bolted to the outside. Your box is only as strong as the weakest part. Hope that helps.
www.stereomayhem.com
yeah idk if u show me a pic of it done i will get it
1995 Ford Mustang 3.8l V6 5 Speed
Plans:
  • 2 12 inch dc Level 4s
  • DC 2.0k Amp
  • KCA 1/0 Power Amplifier Installation Kit
  • 220 Amp Alt
  • XS Power 12V D925 AGM Battery
  • Stinger Volt Gauge
  • Rockford Fosgate RCAs
  • Box built from birch. Probably tuned to 32 Hz
  • 0 gauge wiring for extra battery
  • Dynamat
“I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.”
Al McGuire
“The only mystery in life is why the kamikaze pilots wore helmets”
Al McGuire
remember this always
Close only counts in horseshoes and hand grenades
what size ring terminal do I need?
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
Just use a ring terminal that will fit on the size wire that you are going to use. Put a bolt through a hole in the side of your box with the ring over it. On the other side of the side put another ring on the wire to the amp. Give me a few minutes to get some pics.
aight
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
I just drill a hole and feed the wire thru then caulk the hole shut..... easiest and cheapest way.
Head Unit: Pioneer DEH-P6000UB
Sub Amp:American Bass VFL 500.1
Subs: 4 Fi BL 18's
Enclosure:21.5 Cubic foot flat wall tuned to 40 hz
Batteries: 3 Kinetik 2400's in the back, Kinetik 1200 under hood.
Mids & Highs: 4 Kicker DS 6.5 coax in doors, 2 Kicker DS coax in pillars
Highs Amp: Kicker kx250.2, kx100.2
Wire: 4 Runs 1/0 gauge Knukonceptz
im gonna do the bolt thing any suggestions on what size bolt
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
Guest reestblazer
not the best pic to show you but you should be able to get a idea of it.
what you need to do is get your ring terminals first and then take them to home depot/lowes with you and measure from from there. get some washers too.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
  • Who's Online   0 Members, 0 Anonymous, 1582 Guests (See full list)
