77-AUDIO Posted September 29, 2008 Report Posted September 29, 2008 When adding another battery what do I need to do other than run the power and ground cables to the back. That I have already done. Do I need an isolator???? PPI dbl dinDC Level 31.77cubes net tuned to 33htz.DC audio 2.0kCT Pro Audio 8" in front, 6.5 in rear
wasted ink Posted September 29, 2008 Report Posted September 29, 2008 just make sure you fuse at both ends of the power wire, no more then a foot or so away from the battery. also, its not necessary to do a ground run, you can ground the rear battery to a good ground point near the battery Wasted, Incorporated Up Front: Optima Yellowtop HU:Pioneer Avic N1 w/ 2007 upgrade Front Stage: MB Quart 6.5 comps Rear Fill: Infinity Reference Sub Stage: RE MT 18 Sub Amp: Undecided Sub Enclosure: 5.5 cubes tuned to 33hz Absolute Terminals SkyTec 5100RS 2-Way LCD Pager KnuKonceptz Wire My Build Log
MECHMAN Posted October 1, 2008 Report Posted October 1, 2008 Friends, don't let friends install battery isolators. 1-888-MECHMAN www.Mechman.com [email protected]
