I will most likely be getting a Orion 2500D.
owners manual.. http://www.orioncaraudio.com/Support/Manua...ual%2047410.pdf
What kind of electrical support would be required to run it at half ohm daily? I will be upgrading the alternator... just not sure what engine is going in my truck..
Would some extra fans or something be a good idea?
I'd look at a good 300 amp alt, and as big of Kinetik or Powermaster you can get under the hood, with a HC2400 or a D3100 in the back. That should be overkill actually as those amps only draw 250-275 amps full tilt.
HU: JVC KD-AVX1Speakers: Stock BlazerSub: 2 Mass Destruction Car Audio Sidewinder 12"Amp: Orion HCCA-D1200 @ 1ohm (600 RMS)Box: 3.0 cubes tuned to 35
at 1 ohm
I didn't read that part. I honestly wouldn't recommend running it that low. My Orion's didn't like it. They played just fine but they got warmer than usual (expected) and got pretty power hungry. If possible run another HC2400 or 2.
Hmm. I guess I could wire it to two ohm, as I have two dual 2s, or just try and find another one..
What woofers are you running off it?
It will run at .5 just make sure you've got the electrical but if you can afford it I'd sell it and run a pair of http://www.sonicelectronix.com/item_7559_O...CCA-D2400.html# strapped at 2ohm. it will show you your 2400 watts and you will be looking at 230-240 amps of draw.
Meh thats to expensive. Could run some SAZ-1500Ds strapped for that price.
these things pull over 400 amps of current at .5 just so you know. I had a 260 amp iraggi and two yellow tops and big three done and got major dimming still. They do serious power but you are going to need a ton of juice for it.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 1011 Guests (See full list)
