I plan on putting a 1400 watt system in my truck. I wanna know is 4 awg good enough or should i run 1/0 from the battery to a distribution Block and run 4 awg from there. Im gonna do the big 3 and use a yellow top. My car is a 1996 jeep cherokee. Will my car be able to handle 1400 watts with stock alt?
if your talkin rms, then you will have a little headlight dimming but yeah it will work fine. and i would go ahead and run the 1/0.
DD M4
Rockford Fosgate P500-4
SoundQubed HDC415 w carbon fiber cap
2 Rockford Fosagate T1675-S
XS Power D3400 Under Hood
XS Power D5100 in rear
Michael Singer 200A Alt
Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
definitly 1/0 ga. you might want to add another amp later.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
yep. thats the same reason i recommended it. (lets face it, we all upgrade in the future.)
DD M4
7 years ago i started off with 8 ga as my power wire and now i'm using it as speaker wire.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
same here...but i started 3 years ago with 8awg and using it as speaker wire now
new setup in the works
  • Who's Online   0 Members, 0 Anonymous, 4546 Guests (See full list)
