94 Civic Spl Enclosure Trunk Only
SPL KID
this is by far one of the best trunk boxes ive seen / heard. its in civicman's car. it burps 148.2 you could do a few mods and maybe fit 15's but 4 12's is out of the question.
Posted Image
I Rock 4 Doors 4 More Whores!
SMD SUPER SELLER
my seller feedback http://www.stevemead...-mama-feedback/
more seller feedback http://www.stevemead...-slaps-yo-mama/
2 ideas I whipped up just now... both forwards like what B slaps posted.
Blue is box outline, black is subs (4 10's by the way :P) and red is ports.
Round ports are 4" aeros.
I don't know how much room you have so meh, give it a look.
Posted ImagePosted Image
10.x volts fo' life!
BOON I like those idea's what do you figure the face dimensions to come out to be? I can measure out what I got to work with.
And I have 4 10's not 12's The ISOBARIK idea definetely Posted Image
NSPL 2001 Trunk 251-500 world champion. 2009 2nd place 0-1800 147.9 under 1800 watts. 2011 0-3601 Trunk Champion. No Typo Current 0-3600 Trunk WR Holder! 149.9 (0-1800) /147.5 (1801-3600) /???.? (3601-up) need new front window first! TEAMHIGHX-CURSIONsig-1.jpg
Learn to be quiet about what your workin on.. L O S E = (L)etting (O)thers (S)ee (E)verything
16 x 35 is the opening i got to work with usable. The outside of that will have to be built off from rest off the trunk.
Picture is bad repost it up! I have atleast 28 inches of depth on top off the 16 x 35-36
I'm not at my computer, but I will repost it when I get a chance, it worked earlier but something with photobucket screwed it up. But, if youlook at PTCary and Meade's setups, then you could build a setup that's similar, but using two 10s per side. it is basically three chambers, two of them are slot ported on the front, the subs are firing into the middle chamber which is about 14 in tall and 11.5 in wide which is open towards the front. the box size that I designed is about 16hx35wx22 depth.
Posted Image
Bass Music Producer • Photographer • Graphic Designer
Deep Sector Boom...
that's like 2.4 cub ft per pair of subs before displacements. How much airspace should they be getting in a SPL setup??
  • Who's Online   1 Member, 0 Anonymous, 2135 Guests (See full list)
