Killing My Stock Battery
Will having my 2 15 inch ma audio 1500 xl subs with ma hk1398 2 channel amp kill my Battery? if so what can I do to not hurt my battery? and what should I get?
PS Im trying to tell my dad to let me have my subs in my car so He wants to know that my battery will not be killed.
1995 Ford Mustang 3.8l V6 5 Speed
Plans:
  • 2 12 inch dc Level 4s
  • DC 2.0k Amp
  • KCA 1/0 Power Amplifier Installation Kit
  • 220 Amp Alt
  • XS Power 12V D925 AGM Battery
  • Stinger Volt Gauge
  • Rockford Fosgate RCAs
  • Box built from birch. Probably tuned to 32 Hz
  • 0 gauge wiring for extra battery
  • Dynamat
“I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.”
Al McGuire
“The only mystery in life is why the kamikaze pilots wore helmets”
Al McGuire
remember this always
Close only counts in horseshoes and hand grenades
Not bumping your system with the car off would help not to kill the battery
1997 S10 EC
Whats in it
106.9 Sq.ft. Hushmat
DB Elec. 250 amp alt.
HC800&HC1400
MLA Module
Alpine 9886
Knukonceptz wires
Clarion EQS746
poopy Alpine door co-ax's
Change IS Coming
so when driving I will be fine? Also will it shorten battery life
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
well its a stock 2000 chevy cavalier alt and a new battery put in a month ago by the local auto store so ther ya go. i will not putin a new alternator
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
do the big 3 and you should be fine. if you come into problems hit us all back.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
thnks i will if i do
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
If you run it flat ONCE the battery is pretty much fucked.
Flooded lead acid batteries never truly recover from being fully cycled.
As long as you're careful to never run it right down you're ok :)
10.x volts fo' life!
  • Who's Online   0 Members, 0 Anonymous, 1011 Guests (See full list)
