I've seen this thing on ampguts, but can't find it on there website, however they have a VRA4000D, so is the VR4000D like a older model? I'm thinking about buying one and its not overly far from me.
"Class "D" subwoofer amplifier
1 x 2000W @ 4 ohms (12.5V)
1 x 4000W @ 2 ohms (12.5V)"
Should be enough jooz for my 2 Mach 5 SPL-12s? Do they do rated.
they need a strong electrical system...
will do about 4800w rms @2ohm at 14.4v
very reliable amps and are very durable
the vra is the newer model
I want more xfire amps :(
Team Devastation Mixed Martial ArtsMachado Brazilian JiujitsuOnce I lock it on there's no escape I don't train to make you tap, I train to tear your arm, leg, or head off. Its your job to tap before I can do that -Pain is only weakness leaving the body, its kill or be killed and only the strong survive...Rockford FosgateDigital DesignsFi Car AudioCrossfire Car Audio
sounds like a nice alternator or two needed along with 2-4 good batteries .... if not more.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
x252 that amp is extremely efficient and does its rated power @ 12.5v...........Good luck finding one. A good 200+amp alt and 2-3 big batteries would get it done. 1 up front and 2 in the back should keep ur voltage pretty high.
Edited by CUT BUDDY
00114-1.jpgTEAM MechMan Alternators
thats a good price IMO, I have seen these amps perform in person, I dont think you would be dissapointed at all
hell for that much power. $580 shipped ain't bad.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
Great amps. I loved the pair I used to have. They do not like low voltage at all tho. Make sure your electrical is up to par. They aint known as Catchfire's for nuthin.
A half-wit gave you a piece of his mind, and you held on to it.
anythings possible with the right build =] we accept visa and mastercard =]
