Ya I hear ya.. I don't like using those connectors either... You already have a fuse back there? You can't just put a longer piece after the fuse?
prolly what I am gonna do.... but the ground will probably go into a distro block with a 1/0 in and 1/0 out....
2007 Toyota FJ Cruiser Voo Doo Blue
my upgrades and "build" thread.
My Kulicki Box Build
-Alpine 9887 head unit, KTX-100EQ imprint-( sound quality for dummies! ). - MB Quartz 3.5" in back pillars
-Sundown Audio SAX100.4 - JL Audio 3 way 6.5" component set XR653-CSi ( doors and dash )
-JL Audio 2 way Component set XR650CSi
- Alpine MRD - M1005 - Alpine Type - R 12" subs -- 2 - 12" s in a Pete kulicki designed box.
-Alpine High speed Ipod cable, and KCA-SC100 with Sirius sat. radio
-All wiring is Stinger 12 gauge and HPM Level 3 RCAs, KnuKonceptz Kolossus Power and ground and Big done in 1/0,
-270 sq. ft. of Damplifier Pro, 36 sq. ft. of Overkill Pro, 6 full sheets of Luxury Liner, and a gallon of spectrum-
-2 Powermaster D680 Powercells in back
FINALLY !!! I GOT IT METERED ON THE TERMLAB !!! I did a 140.2 at 42 hertz.
Shoehorn, BFH, forklift,duct tape and some zip ties
Let me get this right. If I run a battery in the rear, I need to fuse it in the front and put another fuse right before the wire goes to the second battery?
some people put a fuse after the 2nd battery and some don't but definitely after the 1st and one before the 2nd. you can also use the 2nd battery as a distribuition block (cuts down on money for buying a distribution block and connections). but your graph is correct though.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
