I have two air compressors with 2 5 gallon tank. I already upgraded my alternator to 160 amps but my battery seems to die fast especially when i turn my system on.
What battery should i upgrade to?
The Project!!
1954 Trunk Build
http://www.stevemeadedesigns.com/board/topic/102529-1954-chevy-belair-trunk-build/
The Daily!!
Head Unit: Alpine 9883
Subwoofer: 2 12's DC Level 4 XL
Amplifier: New DC 3.5 K
Rear Center Console: 1 8' DD 1508
Amplifier: Rockford fosgate 500
Mids and Tweets: Beyma tweets
e36 Trunk/Subwoofer Build
http://www.stevemeadedesigns.com/board/ind...showtopic=27903
are those VIAIR 380's or 480's , or even if they are some other model , for instance , my 2 VIAIR 380's only draw 32 amps . so i think you have some other electrical issues , cause thats not that much of a draw on your battery ( equal to about a 300-500 watt audio amp ) . hope that helped........ btw , do not let your compressors run while the car is off , that can drain your battery some . if you have upgraded your electrical for a system (audio) , im pretty sure your getting a decent battery , right ? ,if you say yes , then that battery should be fine...................
Edited by toyonbags
put the biggest powermaster battery you can fit up front and add a D3100 in the rear the 3100 is a beast.
i got the 480's... yeah, i use to run it with the car off and i learned quickly as my battery died real quick.. it could be my amp then that sucks the juice out. cause i noticed everytime i hook it up, my battery dies...
The Project!!
1954 Trunk Build
The Daily!!
right now, i have the stock size battery for this car. which is real small. so powermaster huh... how about the kinitekzzz?
The Project!!
1954 Trunk Build
The Daily!!
Fully dumped..
The Project!!
1954 Trunk Build
The Daily!!
looks good mang..and upgrade your batt that'll help you alot..
The only way to get smarter is by playing a smarter opponent..
thanks..
The Project!!
1954 Trunk Build
The Daily!!
powermasters are better batteries then Kinetics, thats not an opinion either its fact.
http://www.powermastermotorsports.com/xs_p..._batteries.html
the car is dope, put a dope ass battery or 2 in there and you should be golden
Thanks, cool, imma have to pick up some powermaster batt then.. :spiteful:
The Project!!
1954 Trunk Build
The Daily!!
