spxtreme Posted August 16, 2006 Report Posted August 16, 2006 ok im doing 4 12s walled in what ever car i get should i do 2 subs per chamber or all 4 in a huge ported box? 2001 Roush (New setup comming soon)90 RHD s13 hatch (toy)
lownloud87 Posted August 5, 2011 Report Posted August 5, 2011 if u do all foor in the same chamber add dividers the depth of the sub so the subs dont work on each other. if u r gunna do dual chambers then same answer. ive been doing audio for 10 years and i rarely c ppl usingone chamber for 4 subs in a wall, that being said id go for one chanbers for each pair of subs. and make sure u reinforce the box. Wicked 4 play car club 2002 Chevy 2 door blazer Real soon setup head unit: PTID-8920B subs: 4 12's or 2 15's hevent made up my mind on brand,ported at 33hz amps: for sure two RF 300.4' for mids and highs, 3sixty.2. stuck on wat sub amp ill be using power supply: big 3 1/0, 2 runs of 1/0 power wire and 2 runs of 1/0 ground wire bacc to the second battery, 8awg, 4awg and depending on the sub amp 4 to 1/0 power and grounds for it. speaker wire: 12awg speaker wire and 8awg for subs speakers: 4x6's dash, 6 1/2 components doors, 5 1/4 components kicks, and 6x9's back. all Infinity Reference misc.: 8000k hid low beams/projector headlights, 3/3 lowering kit, D3400 xspower batt up front and rear, ad244 145 amp alternator
Guest Posted August 5, 2011 Report Posted August 5, 2011 if u do all foor in the same chamber add dividers the depth of the sub so the subs dont work on each other. if u r gunna do dual chambers then same answer. ive been doing audio for 10 years and i rarely c ppl usingone chamber for 4 subs in a wall, that being said id go for one chanbers for each pair of subs. and make sure u reinforce the box. Last Active: Aug 03 2008 11:55 AM i think you're a little late bro. edit: also i fail to see how if you do a single chamber, the woofers are going to work against each other. i dont see how this is possible when theyre all moving exactly the same.
RAM_Designs Posted August 5, 2011 Report Posted August 5, 2011 if u do all foor in the same chamber add dividers the depth of the sub so the subs dont work on each other. if u r gunna do dual chambers then same answer. ive been doing audio for 10 years and i rarely c ppl usingone chamber for 4 subs in a wall, that being said id go for one chanbers for each pair of subs. and make sure u reinforce the box. I rarely see people dividing the box into separate chambers. A single common chamber is the trend nowadays. The subs don't "work against each other", but you do have to make sure that you have the subs installed in a fashion that doesn't cause weird loading issues. Ryan Miskin - owner of RAM Designs I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script> 2200+ designs since March 2011...
skittlesRgood Posted August 5, 2011 Report Posted August 5, 2011 if u do all foor in the same chamber add dividers the depth of the sub so the subs dont work on each other. if u r gunna do dual chambers then same answer. ive been doing audio for 10 years and i rarely c ppl usingone chamber for 4 subs in a wall, that being said id go for one chanbers for each pair of subs. and make sure u reinforce the box. hahaha fail in every possible way. If I answered you in a well mannered, informative way, you asked a good question or had a good attitude. If I was an asshole, you asked a stupid question or you had a fucktard attitude... or I was in a bad mood. Team BassickHU: Pioneer AVIC Z110Front: Peerless SLS 6.5", Peerless HDS 4", Rainbow tweeter - running activeAmp: JL HD600/4 and DC 4 channel (bridged to midbass)Processor: JBL MS-8Subs: 2x 12" AA MayhemsAmp: DC 3kElectrical: DC power 270xp alt. 1/0 big 4. XSpower D3400 and six D680s. http://www.stevemeadedesigns.com/board/topic/121795-29-update-the-buick-is-getting-a-rebuild/ Top career scores: DBdrag 151.7 MECA SQ 82.25My SOTM build Yeah. im pretty sure they dont warranty retarded people.
lownloud87 Posted August 5, 2011 Report Posted August 5, 2011 first of all my bad. didnt c how outta date the thread was, second ive never built a wall but thinking about it for my blazer, 3 the only reason i said nething bout a divider between the subs is cuz thats excatly wat steve said bout his divider when he built the wall in his honda. so excuse me for makin a couple mistakes. ive been doing audio for 10 years and cuz noone ever ask me to build a ported box for them im just now getting into it. ive built sealed boxes since i started, but now ppl r telling me that in order to get the numbers that i want outta my set up i need a ported box so im trying to learn and help out in any way i can with someone elses build, like i do with everybody around me. one more note, like i told another member, im like the steve meade of my club and of my area when it comes to install's bcuz my blazer hit harder then anybodies system that hung out with me. later Wicked 4 play car club 2002 Chevy 2 door blazer Real soon setup head unit: PTID-8920B subs: 4 12's or 2 15's hevent made up my mind on brand,ported at 33hz amps: for sure two RF 300.4' for mids and highs, 3sixty.2. stuck on wat sub amp ill be using power supply: big 3 1/0, 2 runs of 1/0 power wire and 2 runs of 1/0 ground wire bacc to the second battery, 8awg, 4awg and depending on the sub amp 4 to 1/0 power and grounds for it. speaker wire: 12awg speaker wire and 8awg for subs speakers: 4x6's dash, 6 1/2 components doors, 5 1/4 components kicks, and 6x9's back. all Infinity Reference misc.: 8000k hid low beams/projector headlights, 3/3 lowering kit, D3400 xspower batt up front and rear, ad244 145 amp alternator
lownloud87 Posted August 5, 2011 Report Posted August 5, 2011 o btw one more thing i did not say the subs would work against each other i said that they would work on each other. in other words with a divider, if u blow one sub its easier to figure out which one is blown then if u have no divider, without taking the subs outta the box. that has worked for me n the past. Wicked 4 play car club 2002 Chevy 2 door blazer Real soon setup head unit: PTID-8920B subs: 4 12's or 2 15's hevent made up my mind on brand,ported at 33hz amps: for sure two RF 300.4' for mids and highs, 3sixty.2. stuck on wat sub amp ill be using power supply: big 3 1/0, 2 runs of 1/0 power wire and 2 runs of 1/0 ground wire bacc to the second battery, 8awg, 4awg and depending on the sub amp 4 to 1/0 power and grounds for it. speaker wire: 12awg speaker wire and 8awg for subs speakers: 4x6's dash, 6 1/2 components doors, 5 1/4 components kicks, and 6x9's back. all Infinity Reference misc.: 8000k hid low beams/projector headlights, 3/3 lowering kit, D3400 xspower batt up front and rear, ad244 145 amp alternator
korey_hofer Posted August 5, 2011 Report Posted August 5, 2011 just to straighten out the info and put it into one post. Common chamber enclosures have been known to be louder. The subs can work against each other if one sub is unloading massively or is seeing less power than the others. Even with one sub unloading common chamber tends to be louder. Just because it's the same concept, clam shell walls and tunnel walls do not cancel out either, the waves combine to be more power full. Single port systems usually meter louder than multiple as well, that is if it's the same type port. SQ boxes I have always done separate chambers mostly so I can make sure the size is exact and that the waves are not mixing and becoming muddy. previously known as wenn_du_weinst aka fucking internet coward supreme. I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
