How Much Power Increases
chronic2001
ok so if you had a amp that was rated like this rated at 12.6V
Output POwer at 12.6V:
2 x 200W @ 4 ohms (THD < 0.006%)
2 x 400W @ 2 ohms
2 x 800W @ 1 ohm
2 x 1200W @ ½ ohm
1 x 2400W @ 1 ohm bridged
Fuse: External 400A
44" long (112 cm), 36 lbs (16.33 kg)
how many watts at 1 ohm bridged would you actually get running it at a consistent 14.8V
Pioneer deh-8300UB
6- Image Dynamics CSX6.5v2
4-Image Dynamics XS-28 tweeters
4-Sundown Audio sa8v2's
1-Sundown Audio SAX-200.4
1-Sundown Audio SAX-1200d
1-Mechman 270a alternator
1-XS Power D3400 under hood
Second Skin Damplifier Pro Deadener
Kicker & Knukoncept 1/0 wiring
Big 3 upgrade
I would estimate approximately 15% more. Although some amps scale the power very differently.
Might help if we knew what the amp is... although at 44" and a 400A fuse it sounds pretty heavy duty.
EDIT: Oh, USAmps VLX-400?
Still, probably 15-20% more power.
10.x volts fo' life!
class A/B 2 channel
Yup, that model came out in 93' I still have the catalog I got from US Amps in 92'
class A/B 2 channel
ya i got a red vlx-400, red usa-200, polished us 4300x, and a purple us amps optimizer and a couple of the old lanzar optidrive series
i talked to greg from us amps and he said that the vlx-400 couldn't see 15.1V or it would go into protection i still dont understand i thought class A/B was unregulated and could take like 16V with no problems
Pioneer deh-8300UB
Big 3 upgrade
Amp class doesn't matter with regards to voltage handling... almost every single amp uses the same style of MOSFET switching power supply, which unless regulated, will take as much voltage as you like until you reach the limit of the components voltage ratings (or thermal issues overwhelm it)
In this case, it probably uses something like 16v caps so they make it protect at 15.1v...
thanks to all you guys that school me on all this shit cause i know the basics but still have so much to learn its like free schooling i love it thnx again
Pioneer deh-8300UB
Big 3 upgrade
you have definitely came to the right place potna.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
  • Who's Online   0 Members, 0 Anonymous, 807 Guests (See full list)
