i have a 10 inch ssd coming in tomorrow. wat would be a better box to put it in? it request a .9-1.5 cuft box. and was wondering want would be the best for it? i found a prefab box with 1 cuft and after sub placement it would be .88 cuft. or should i go bigger? if so how big?
Live Fast Die Fun!!!!
Use it or lose it
I've found that with most 10's that are not of entry level quality they usually work well in 1.25 cubes. You didn't mention what kind of power you'll be using and the more you plan on having the smaller you can make the box. If you're underpowering it then I say go with a bigger box to compensate for some of the power loss.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
146.4 sealed on the dash at 37hz
2001 Focus ZX3: RETIRED
Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore Champion
Highest NSPL Scores to date:
154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz
155.2db unofficial on dash at 43hz
right now i am going to be under powering with a 1000 watt insignia amp for a little but i plan on using about 750 rms when i get the new amp.
Use it or lose it
so .88 cuft would be to small since it recommends .9 to 1.5?
Did you read what he said....and prefab = garbage.
Vehicle: 1997 S10 Blazer 4dr 4X4
Exterior: Rear End Bagged, Black Grill, Lifted 2"
Amplifiers: Rockford Fosgate T8004 & T10001bd
Batteries: 2 Stinger SPV35, Kinetik HC2400
Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v
Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube)
Headunit: Eclipse CD3200 w/ 80G iPod
Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors)
Subwoofers: 1 15" Fi BL Fully Loaded
Wire: All 1/0g Kicker Hyperflex
My YouTube Videos
My Fiberglass A-Pillar Build
My "Seamless" Looking Box Build
My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer)
My Stealth 8" Fiberglass Build (for '05 TrailBlazer)
My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk
My feedback/references...
do you think one of you guys could help with box designs. i am having a hard time making some.
was that a sealed box or a ported box ????
must be nice huh
