Ok this one goes back before I built my car  FOR REAL (I had 2 cvr15's in a custom box built by a shop and i was happy with it).
Ride: 1995 Ford escort 2dr
I don't have any full shots of the car but it was this color green and only diff is 2dr not 4dr.
Deck: Alpine Cd (model ## I forget)
Front mids: 6 1/2" Infinity Kappa Components
Rear mids: 6 1/2" Infinity Kappa 2 ways.
Subs: 2-JL Audio 12w3-D2's (version 1) 2 ohm mono @ amp.
Amp: JL Audio 500/5 5 channel.
Goals:
The best possible sound Q while still being able to drown out douche-bags in traffic and scare old people.
So this was OFFICIALLY my first ever attempt at makin kick pods.
Sorry I didn'd get a shot of layin the base-matt but here it is w/ the rings positioned
The owner.
Here we tried 2 different approaches as an experiment: The one on the left is the passenger side pod and the front portion was formed using planter's foam (that really lightweight, crumbly green foam in the bottom of flower pots/vases) and it was cut to form w/ a razor blade. The one on the right is the driver side and it is wrapped in black stretchy material.
Passenger side
Gettin there
And the driver side gettin moulded in
What a damn mess!
Tearin it all apart to run wires
Driver side after a layer or 2 of bondo and some rubbin with 200grit sandpaper
and the pair
Slave labor hehehe
Wrappin em up in some color matched stretchy carpet
I like to poly fill em for a lil extra "airspace" and thus more mid bass up front
Passenger side gettin mounted & wired
Driver side all done
And here's the "amp rack" I built.
The rack was actually more than you see in the pic, it had a top cover that attached via 2"DOWELS that slid into those 4 drilled 1/2" holes (2 on each side). It was essentially a frame that surrounded the face of the amp and concealed the wires. It sat about 1/4" higher than the face of the amp so it wouldn't get scratched if he put stuff in there on top, but the owner never put the top/cover in and thus, the amp got scuffed in a few places.
The box was custom built by a local shop and black vinyled. It was actually orignally built for his 85 bmw which had 3 amps (2 kenwoods & 1 mtx) and a different amp rack i built. I'm workin on scanning in them pix for ya guys. I didnt' get any pix of em, but had 2 Infinity Kappa Perfect 12's that he swapped in there in place of the JL's. The Sound Q was VERY good, But in the end he opted for a lil more output and good SQ w/ the JL subs.
I think that's it for this one.
EDIT***1-14-06
Since I mentioned it already I guess I'll put his old BMW setup right here instead of makin a new thread.
Ride: 1985 BMW 325E
Frint mids: Infinity Kappa 6 1/2" 2 ways
Rear mids: Polk EX 2 ways (5 1/4" I think)
Subs: Same as above.
Sub amp: 2-Kenwood 600watt 2 channels (part ##?)
Mid amp: 1-MTX 300watt 4 channel (part ##)
1F Streetwires cap.
Center Amp rack by me (black vinyled, Hinged, & held sub amps,wiring, and 1Fcap-see pics) and seperate rack for the 4 channel on driver side QTR panel of trunk in vinyl w/ removable trim ring to access connections (somewhat visible in pics)
This the before setup:
And after: Battery in trunk on far right. (stock location)
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
looks very good.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
lookin good.
Cell phone pics?
HAHA NO!
Actual Hard copy pix from ONE-TIME use cameras (like 2 for $5)..then I scanned the pics onto my pc w/ my scanner. I know shitty quality but yall get the idea.
I think my cell pix (like on the lexus) were better. Oh well. working on a digi cam soon enough. Cant really go take more w/ the celly cuz this cars long gone.
