did you try cleaning your throttle body? Also your throttle sensor on the side of the throttle body might be bad too.
When I cleaned my K&N 2 months ago I cleaned the T/B also.
Team Deadly Hertz
Just from my experience with my car thats pretty much exactly what it was doing. Thank god Mercedes warrenties theirs to 100000miles cuzz they both went bad b4 that just barely lol but if not it wouldve been over a grand to replace them!
Some people need a sympathetic pat... on the head...with my hammer
Scientia est Vox
DONT BE AFRAID TO USE THE SEARCH BUTTON!!!
SMD SUPER BUYER/SELLER
sounds alot like your cats are bad.
I 2nd this
Just had an 03 silverdao with a 5.3 in the shop wednesday with missfire codes and a cat efficiency issue, damn thing had no power at all. pulled the exhaust loose on one side and she ran like a striped ass ape.
Being you have 02 sensors b4 and after the cat, throw a back pressure gauge on it and get some readings, anything over 2psi of back pressure and yer screwed. and be sure to check them with the rpms raised up as well, not just at idle. If ya dont have access to the tool, just drop the exhaust off one side.
Aftermarket cat assembly aught to run you bout $750. A dealer part would be prefered due to some aftermarket cats not burning correctly and setting codes after replacement but when i called the dealer they were out of stock in all the warehouses in the midwest and were on back order.
Good luck man
Edited by kandiman71874
Daily Driver 1999 Kia Sephia
Kenwood DNX-893s
Audison Bit One Processor
2 Dat 4.125's
Sundown Audio SCV-6k
Hertz hsk-165xl's Mids running active        Focal V30 Series Tweeters running active
Sundown Sa-8 v1's in the doors
2 Sundown Zv5 12's
Lots of Hushmat
Big 3+ and 3 + & 3- runs of Trystar 2/0
2 Dc Power Engineering 320 HP Alts
2017 Comp Vehicle
2006 Toyota 4 Runner
Kenwood Excelon DNX-893s        Audison Bit One HD DSP
4 Sundown Sa 6.5v2 Component Sets
Focal Access 6.5 2 ways
Sundown Audio Sax-50.4        Sundown Audio Sax-100.4
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
2 Northstar asmagm 480's
2 Dual 1 Sundown Nightshade v3 12's
2 Sundown SCV-7500's
All SMD Fuse Holders
Shitload Of Sundown 1/0
120 sq ft Second Skin Damp Pro
No, Its Not A Burp Truck!!!!
2016 Season 3rd place in Xtreme 1 At Finals
2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations)
2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL
David said:
audio is a lifestyle, not a hobby
newls1
I cant read a tape to save my life... 1/2's are ok, but other marks confuse me
kingsuv
only men who cant read a tape, take it in the ass
kingsuv
you sir, get a pink hard hat on jobsites
I 2nd this
Good luck man
I thought about doing that, disconnecting the exhaust from the headers and see what happens? How much does a back pressure gauge cost?
Team Deadly Hertz
The shop next to my house told me they will replace each cat for $240 each.
Keep the old ones and turn them in for scrap. The have platinum in them and you can get about $80 each
DC.jpgDC POWER
  • Who's Online   1 Member, 0 Anonymous, 875 Guests (See full list)
