4 Atomic Apxx 15" 4rth Order Bandpass Wall Build
damn dude, lookin good
4th order FTW
Lovin the battery Distro up front!
batt rack goin 24v?
no those are 8 volt batteries wired up to 16/18 volts
THAT IS FUCKIN BADASS BRO!! i have never seen a distro that big usually with that many runs youll see a buss bar but that is crazy
:D
R.I.P!
(Nov-29-2009)
92 explorer
current build
looking sweet man...im hoping that you reach your goal man...
thanks man me to but i know i wont, my goals 155db at 30 hz
but im building this for bassrace 149.9-159.9 peaking around 40hz or so so i wont get what i want but i'll still be happy with what i have :D
R.I.P!
(Nov-29-2009)
92 explorer
current build
Hey Douch, I finally seen this build log, here is some tips for you, if your doing a driver side port in a band pass why don`t you rebuild the drivers side wall so it follows the "b" piller for more port area. You dont want all that pressure to stay in the box. If your doing sealed (4th order) try to find tubes to gain as much volume in the back as you can plus better flow with tubes. Ditch all that sillicone and duck tape a use bondo and or shortstrand fiberglass. If you got to tape something up use tin tape and smooth it out. Just some stuff i have learned in the years :D Nice avitar :good:
Mike and Mark
[email protected]
yeah i know im staying away from tape and silicone and going to glass/bondo the loading wall and going to do it right this time once everything like the loading wall and what not is all figured out
R.I.P!
(Nov-29-2009)
92 explorer
current build
Good plan. Can you still brace up the walls and back wall still? I would screw some 2x4`s or steel, just something to stop those big pannels from resonating and flexing.
Mike and Mark
[email protected]
i was actually wondering myself about that i can take out the back wall and was thinking of taking it out and bringing the box's back as for as i can i can get a good 2.5-3" back taking that out and then just use 2x4s on the back of those box's to brace it up (im making 4 sealed 2 cube box's)
R.I.P!
(Nov-29-2009)
92 explorer
current build
Just out of interest, how are you charging the rear batts? Second alternator? Kinda no need for all that 0ga lol...
10.x volts fo' life!
there was a single batt before so i had all these runs ran for that then decided to switch to 16 volt system and i know i dont need all that 0 gauge
and it will be a 16 volt alt powering the rear with stepdown for the front batt
R.I.P!
(Nov-29-2009)
92 explorer
current build
