so are you going to seal the trunk/back doors off with woods or just going to leave it and use the whole back area like an IB box
R.I.P!
(Nov-29-2009)
92 explorer
current build
Well if I do it with wood it'll be very time consuming and it will decrease my air space. My plan is to make a thick fiberglass bubble around the back. I want all the pressure shooting forward and I don't want to lose air in the back.
Need an install? Hit me up.
[email protected]
my moms got a PT and the doors do arnt that strong and while driving you can hear the air flow coming in and so i'd imagen 32 subs pushing outwords is goign to make them want to open even more
i hope this makes some sence
R.I.P!
(Nov-29-2009)
92 explorer
current build
Another note on that, there are vents in the back for air circulation with little rubber check flaps. Those most likely create that effect, but this car is damn near air tight (in that aspect). I've sealed every hole, vent, and plug in here. All that's left is the rear hatch.
[email protected]
The front of the box is carpeted and I ripped the battery cover out to redo the grounds. I'll post pics at home..
Did anyone have some insight on the amp getting hot?
[email protected]
could just be its working hard my amp did that when i was cranking it and it was not vented... give it some air and try again....
The set up your talking about would sound great in my Tahoe. Trade you my dog for it. He has one eye but that only makes for bad depth perception so hey so what if he is running into shit, look at it this way he is easy to sneak up ninja style on. (right side only)
</div>
Well I felt bad, so I took some pics of some other things for fun. Plus I took pictures of the latest.
Posted Image
Posted Image
Here is the way the box looks carpeted. It's not completely done, but it's what I've done today. I also rebolted one of the rods and relocated some of the 2x4 bracing on the bottom.
Posted Image
This is my Panasonic. There are many like it, but this one is mine.
Posted Image
Here is where I mounted my bass knob and my gauge switch. It's all right on the dash so there's no wire clutter.
Posted Image
Posted Image
Here are the A pillar gauges. They are Voltage, Amp Temp, and Current.
That's about all I got though for now... I'll try to carpet more tomorrow and redo my grounds, but I'm having a hard time finding a really SOLID spot to bolt down... I might even weld a ground bar to the bottom of my B-pillar, but that's still up in the air.
[email protected]
My amps are out for repair.
Once they come back and I install them, you guys will be the first to see them in action.
I promise. Until then, there's nothing I can do.
[email protected]
Alright, here's the update on what's been done today.
Posted Image
It looks good for now, I'll redo it some other day to make it prettier.
The amps should be coming back this week, and I'm off Thursday through Sunday so the build will hopefully be completed this week!
If the amps don't come back, however, I will build the amp rack and finish all of the beautification, so all that's left would be putting the amps in.
It should be done soon guys!
[email protected]
