How To Make 45 Degree Corners (ported Box)
wasted ink
***mods - feel free to move to another section if necessary***
just as the title says... this is a quick how-to on making 45* corners...
get a piece of material, i use 3/4" MDF.. make sure it is at least the length of the inside height of the box.
Posted Image
next, i use a combination square to make my cut lines at 45 degrees..
Posted Image
make sure the lines are perpendicular, of course..
Posted Image
set your blade angle at 45 degrees, and set the fence accordingly..
Posted Image
Posted Image
line the blade up with the cut lines made on the end of the piece, and lock the fence in position..
Posted Image
carefully rip the piece down, using push sticks if necessary.. the piece should now look like this..
Posted Image
Posted Image
Posted Image
the next step will differ, depending on the saw you are using. the saw i use only tilts the blade one way, so i have to flip the piece accordingly to make the next cut..
Posted Image
the piece should now look like this:
Posted Image
now, if the piece was longer than the internal height of the box, put it in a corner, and mark it with a pencil
Posted Image
Wasted, Incorporated
Up Front: Optima Yellowtop
HU:Pioneer Avic N1 w/ 2007 upgrade
Front Stage: MB Quart 6.5 comps
Rear Fill: Infinity Reference
Sub Stage: RE MT 18
Sub Amp: Undecided
Sub Enclosure: 5.5 cubes tuned to 33hz
Absolute Terminals
SkyTec 5100RS 2-Way LCD Pager
KnuKonceptz Wire
My Build Log
trim the piece at the line you made... then glue and clamp into place..
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
***note: keep in mind, when making corners for port walls, to measure before making the insert. make sure port width stays equal from one end to the other, corner inserts may have to be made wider or thinner to keep width equal.
Sub Stage: RE MT 18
Sub Amp: Undecided
Absolute Terminals
KnuKonceptz Wire
My Build Log
i wish i woulda seen this before i built my t-line i got lazy with it and just put corner round in all my corners but i'll for sure remember this next time i build another box.
1997 Dodge Ram Van 2500
Big III addition with 1/0 awg wiring all throughout
Lightning Audio Strike S4.1000.1D
Jenson XA2250
2 - 12" Mtx Jackhammers JH55
3ft cubed box sealed under the rear bench seat
Pioneer DEH-P6000UB head unit
MB Quart FWA 160 components up front
even if one person gets something out of it, itll be worth my time writing it...\
thanks for the sticky roscoe!
Sub Stage: RE MT 18
Sub Amp: Undecided
Absolute Terminals
KnuKonceptz Wire
My Build Log
good stuff. i wish o wouldnt have sold my tablesaw. i am now cutting mine with a circular saw. it sucks.
----reference's----
meade916
measure the distance from the blade to the edge of the base on your circular saw and just use a straight edge as a rip fence clamped to what your cutting with some C Clamps, it takes a little longer, but you will get the same results as you would have using a table saw if you are anal about your markings...
Daily Driver 1999 Kia Sephia
Kenwood DNX-893s
Audison Bit One Processor
2 Dat 4.125's
Sundown Audio SCV-6k
Hertz hsk-165xl's Mids running active        Focal V30 Series Tweeters running active
Sundown Sa-8 v1's in the doors
2 Sundown Zv5 12's
Lots of Hushmat
Big 3+ and 3 + & 3- runs of Trystar 2/0
2 Dc Power Engineering 320 HP Alts
2017 Comp Vehicle
2006 Toyota 4 Runner
Kenwood Excelon DNX-893s        Audison Bit One HD DSP
4 Sundown Sa 6.5v2 Component Sets
Focal Access 6.5 2 ways
Sundown Audio Sax-50.4        Sundown Audio Sax-100.4
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
2 Northstar asmagm 480's
2 Dual 1 Sundown Nightshade v3 12's
2 Sundown SCV-7500's
All SMD Fuse Holders
Shitload Of Sundown 1/0
120 sq ft Second Skin Damp Pro
No, Its Not A Burp Truck!!!!
2016 Season 3rd place in Xtreme 1 At Finals
2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations)
2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL
David said:
audio is a lifestyle, not a hobby
newls1
I cant read a tape to save my life... 1/2's are ok, but other marks confuse me
kingsuv
only men who cant read a tape, take it in the ass
kingsuv
you sir, get a pink hard hat on jobsites
thanks guys
Sub Stage: RE MT 18
Sub Amp: Undecided
Absolute Terminals
KnuKonceptz Wire
My Build Log
  • Who's Online   0 Members, 0 Anonymous, 1137 Guests (See full list)
