Newbish Question
a_steezy
is there a noticable difference running 2 ohms to 1 ohm??? for example how many amps does a saz-1500d pull at 1 ohm and 2 ohms?
i couldn't find the the draw or any numbers on it, but if someone knows it i'd also like the stats on a saz-3000d
'98 Dodge Durango 5.9L
5% front windows, 2.5% on all backs
Alpine CDA-9883
Kicker ZX350.4
Kicker KS650's in all doors
Kicker 1/0 hyperflex
hhh
Alpine CDA-9883
Kicker ZX350.4
You lower your ohms from 2 to 1 your draw more amps of current. increase power, and have less effciciency due to heat. Most amps do more power at lower ohms and some don't...
edit: the rating for the 1500D is 800w....but you can prolly expect 1000-1100wrms
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
i that 1 ohm draws more amps, but how much more??? and is it a noticable difference?
Alpine CDA-9883
Kicker ZX350.4
yes there will be a noticable differnce because the lower you go in ohms the more power you get hence the more power it needs to run the amp
Vehicle:1998 Jeep Wrangler 4.0 I6 with Cherry Bomb and Cold Air Intake,
Speakers:5 1/4 Pioneers in front and back
Deck: Jensen DVD In-Dash
Amp: Lanzar Opti-Drive 2000w
Subs: 2 Boss Chaos Edtion 1000w max (500wrms)
Rubber: Nitto Grappler 35 x 12.50
Fun Things: Cobra CB with PA speaker to piss people off =]
If the listening level is too loud, then your not deaf enough
if all else is held constant, halving impedance doubles draw an output
some amps dont follow this whatsoever, like jbl crown, which draws more at higher impedance, and alpine pdx, which has the same rms and draw at 2 or 4 ohms
Team DC
  • Who's Online   0 Members, 0 Anonymous, 647 Guests (See full list)
