im just not sure if i wire my amp with 1/0 gauge temperarly till i get my 4 gauge would anything happen to the amp?....i have a (crunch Pzi.250.2)....i heard wiring it to a BIGGER wire it might harm it or mest it up.?...i know 1/0 gauge is WAy too big for it but just my cutting some wire off of it till it fits....would that work?
bigger and more wire is always better
R.I.P!
(Nov-29-2009)
92 explorer
current build
Couldn't hurt anything...
'Cept maybe try and get a fuse to match your amp.
thanks!...im gonna fuse it with a ANL 100 amp for now...thats the only fuses i have right now...till i get the rest of my 1/0 gauge for other things...100 amp is good enough?...the amp has (2)30 amp fuses...
100 should be fine.
and the 4 awg is a waste. as already been said bigger is better.
would u try and pull 10,000 gallons of water through 2" PVC or 6" PVC?
Same theory applies here.
"No poor dumb bastard ever won a war by dying for his country. He did it by making the other poor dumb bastard for his country."
George Patton
aight...the amp wouldnt get too hot because i kutt a lil bit of wire to fit the wire into the amp?...
  • Who's Online   0 Members, 0 Anonymous, 2023 Guests (See full list)
