On the other hand, If you want to run Sundown amps daily you should get two 1500's. Once you strap them you don't have to worry about gain matching. Its very very simple to strap Sundown amps.
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
1600 watts at 2 ohm for the Sundown 3000
I do box designs.
well i planning on get 2 sundowns SAZ3000's and putting both in .5 Ohms then i will be running a 1 Ohm systems which i am hoping to get around 6000-7000 watts
Club 150 (15x.x)
Youtube
Future Build:
1x 15" T3 TSNS
2x Sundown Audio SAZ3000d Parellel strapped
If you have a dual 1 ohm sub, there is no way to get two 3000 to read a .5 ohm load each. Its either going to be 1 ohm each or .25 each. I don't like the idea of .25 ohms...
I do box designs.
Well when i was running my 2 dual 1's tto equal 1 ohm after rise it was bout 1.5ohm...but when i wire them to .5 ohm they sit at .7 with rise.. that shouldnt hurt too much should it?
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
You can't wire two dual 1ohm subs to 0.5ohm. It'll be 0.25, 1, or 4ohm.
wow..duh i knew that... well a few weeks ago i wired it so my dmm read like .6-.7ish i think i paralled each sub and wired them in series..
2007 Chevy HHR LT
UNDER CONSTRUCTION
