SPL KID Posted October 31, 2008 Report Posted October 31, 2008 2004 navigator where are the vss wire, power lock/unlock wires, also how do you get the factory amp to work with aftermarket headunit please? colors and locations of wires if possible . Have a remote start and Nav unit to install in one that had factory Nav and contains a amplifier. 4 plugs on back of old unit. NSPL 2001 Trunk 251-500 world champion. 2009 2nd place 0-1800 147.9 under 1800 watts. 2011 0-3601 Trunk Champion. No Typo Current 0-3600 Trunk WR Holder! 149.9 (0-1800) /147.5 (1801-3600) /???.? (3601-up) need new front window first! Learn to be quiet about what your workin on.. L O S E = (L)etting (O)thers (S)ee (E)verything
David Posted October 31, 2008 Report Posted October 31, 2008 http://www.directwholesale.net/diagrams/diagrams.asp?link=DW
SPL KID Posted November 1, 2008 Author Report Posted November 1, 2008 no VSS info or amp info .... NSPL 2001 Trunk 251-500 world champion. 2009 2nd place 0-1800 147.9 under 1800 watts. 2011 0-3601 Trunk Champion. No Typo Current 0-3600 Trunk WR Holder! 149.9 (0-1800) /147.5 (1801-3600) /???.? (3601-up) need new front window first! Learn to be quiet about what your workin on.. L O S E = (L)etting (O)thers (S)ee (E)verything
dr.db Posted November 1, 2008 Report Posted November 1, 2008 On the 2004 navi the speed wire is at the PCM on the passenger side firewall..the vss wire is in the closet plug to the fender...pin number 13....Gray with black I believe!AlWAYS test with a meter before you make final connections.
SPL KID Posted November 3, 2008 Author Report Posted November 3, 2008 Thx Doc. Still can't locate lock / unlock wires. What clip or loom are they supposed to be in????? NSPL 2001 Trunk 251-500 world champion. 2009 2nd place 0-1800 147.9 under 1800 watts. 2011 0-3601 Trunk Champion. No Typo Current 0-3600 Trunk WR Holder! 149.9 (0-1800) /147.5 (1801-3600) /???.? (3601-up) need new front window first! Learn to be quiet about what your workin on.. L O S E = (L)etting (O)thers (S)ee (E)verything
SPL KID Posted November 6, 2008 Author Report Posted November 6, 2008 location of power lock wires please... anyone. what loom are they in?? or plug color they are on NSPL 2001 Trunk 251-500 world champion. 2009 2nd place 0-1800 147.9 under 1800 watts. 2011 0-3601 Trunk Champion. No Typo Current 0-3600 Trunk WR Holder! 149.9 (0-1800) /147.5 (1801-3600) /???.? (3601-up) need new front window first! Learn to be quiet about what your workin on.. L O S E = (L)etting (O)thers (S)ee (E)verything
pstone11 Posted November 6, 2008 Report Posted November 6, 2008 Here's the 03 and the 05 - I can only assume the 04 is the same.. http://www.the12volt.com/installbay/forum_posts.asp~TID~9362 http://www.the12volt.com/installbay/forum_...s.asp~TID~40520 Check out StoneSounds to see my recent builds.Or look at the Flying White Facebook Page!
kylecm85 Posted November 6, 2008 Report Posted November 6, 2008 power lock Pink/yellow- power unlock Pink/lt.green- both are in the driver kick panel or vsm. vsm is located high in the passenger kick panel (VSM)- vehicle security moduale As far as the factory amp turn on there should be a wire in the harness that u use to connect the aftermarket radio. Which is blue with white same as the standard turn on wire.just connect those and it should turn on and if u get bad turn on pop which is common in those u can use a 100 ohm resistor in line and it should take care of the problem. 94 lincoln mark viii h/u: kenwood kvt 614 Excelon comps: alpine type x amps: mtx 1501d mtx 4004 sub:2 DC lv4 12 wiring jl audio 0awg 8 awg sub jl audio 4 awg for mid and highs amp myspace.com/kylecm85 carstereolexington.com
SPL KID Posted November 6, 2008 Author Report Posted November 6, 2008 I found the turn on in another harness but it seems to leave to leave the amplifier on. I think its grn with black on something I think it may be the amp ground perhaps....? NSPL 2001 Trunk 251-500 world champion. 2009 2nd place 0-1800 147.9 under 1800 watts. 2011 0-3601 Trunk Champion. No Typo Current 0-3600 Trunk WR Holder! 149.9 (0-1800) /147.5 (1801-3600) /???.? (3601-up) need new front window first! Learn to be quiet about what your workin on.. L O S E = (L)etting (O)thers (S)ee (E)verything
kylecm85 Posted November 7, 2008 Report Posted November 7, 2008 black/lt.green in the radio harness is a ground. But the amp should not come on if u hook a turn on wire to that. If it s staying on make sure u did not hook the constant wire to the factory turn on wire. 94 lincoln mark viii h/u: kenwood kvt 614 Excelon comps: alpine type x amps: mtx 1501d mtx 4004 sub:2 DC lv4 12 wiring jl audio 0awg 8 awg sub jl audio 4 awg for mid and highs amp myspace.com/kylecm85 carstereolexington.com
