kentb Posted November 2, 2008 Report Posted November 2, 2008 hi guys, i installed a pioneer 5900ib in my sister's 2001 mitsubishi galant attached the ground wire to the mounting sleeve that is connected to a metal part in the dash. it doesn't turn on. so i took the ground off, and wiggled some wires then it worked! i was putting it back and it turned off again. so i tried wiggling more wires and it seems to turn off and on. that is with or without the ground connected to the mounting sleeve. i tried isolating the wires one by one b ut i can't find it. idk, what do you guys think? New System 2 10" Fi SSD, Sundown 1500d Build I build and design enclosures(cheap price), PM ME Kicker L7 Navigator(plexiglass, fiberglass, aeroport) Build BTL 18" Escalade(plexiglass, battery tray) Build http://www.kentbaudio.com Old System
AI James Posted November 2, 2008 Report Posted November 2, 2008 check the harness to be sure all of the pins are connected nice and snug
EricM9104 Posted November 2, 2008 Report Posted November 2, 2008 sounds like a wire is shorting out somewhere. 2015 Honda Civic LX 4dr | 110k miles | Stock 1996 GMC Yukon SLT 4dr 4wd | 260k miles | JVC Head-unit
kentb Posted November 2, 2008 Author Report Posted November 2, 2008 everything was soldered btw New System 2 10" Fi SSD, Sundown 1500d Build I build and design enclosures(cheap price), PM ME Kicker L7 Navigator(plexiglass, fiberglass, aeroport) Build BTL 18" Escalade(plexiglass, battery tray) Build http://www.kentbaudio.com Old System
kentb Posted November 2, 2008 Author Report Posted November 2, 2008 check the harness to be sure all of the pins are connected nice and snug yup i checked that, even pushed it as hard as i can sounds like a wire is shorting out somewhere. like what do you mean? New System 2 10" Fi SSD, Sundown 1500d Build I build and design enclosures(cheap price), PM ME Kicker L7 Navigator(plexiglass, fiberglass, aeroport) Build BTL 18" Escalade(plexiglass, battery tray) Build http://www.kentbaudio.com Old System
Got_Bass89 Posted November 2, 2008 Report Posted November 2, 2008 yup i checked that, even pushed it as hard as i canlike what do you mean? Wire touching metal... Or you tried different ground? Ground could be comming loose or just bad ground... Stock harness didn't have a ground wire??? Passport Build Here Alarm: Prestige APS997A 2-Way/Remote Start HeadUnit: Pioneer DEH-P6000UB Front Battery: Yellowtop Optima D34/78 Back Battery: 2x C&D Technologies High Rate Series UPS12-475FR 134AH Subs: 2x DC Lv4XL 18's Amps: 2x Sundown Saz1500's Strapped Box: 12Cubes 33hz 185sqin Port(15.4sqin per cube) Pillars: AudioBahn AS31Q Front Doors: Clif Designs TX40.5 Back Doors: Clif Designs CD50.4C Rear Speakers: Clif Designs TX46.5 Front/Rear Amp: Kicker ZX350.4 Back/Pillars Amp: Kicker ZX200.2(Looking for another zx350.4) Electrical: 1/0 Scorpion Wire 2 Runs Pos and 2Runs Ground, Knu 1/0 Flex Running to Amps ect, Big 3, JL 8Ga For Speaker Wire, Knu Karma RCA's, Scorpion Volt Meter Deadener: 100 sqft Sound Destroyer Mat And SECOND SKIN Damplifier Pro Door Pack
kentb Posted November 2, 2008 Author Report Posted November 2, 2008 Wire touching metal... Or you tried different ground? Ground could be comming loose or just bad ground... Stock harness didn't have a ground wire??? the the weird thing is its turning on and off even if the ground wire wasn't hooked up. the harness on the mitsubishi doesn't have a ground. New System 2 10" Fi SSD, Sundown 1500d Build I build and design enclosures(cheap price), PM ME Kicker L7 Navigator(plexiglass, fiberglass, aeroport) Build BTL 18" Escalade(plexiglass, battery tray) Build http://www.kentbaudio.com Old System
