well as u know i got my system installed, every thing worked fine til today. i got in my car to go to arbys for dinner start my music low and work my way up well i hit the top of my limit for volume (30/35) and the subs just get quiet still work but quiet. i open my trunk everything looks fine. i check my wiring all fine. after i turn it down for a while it hits fine for 5 sec then quiet. idk the prob any help??????
1995 Ford Mustang 3.8l V6 5 Speed
Plans:
  • 2 12 inch dc Level 4s
  • DC 2.0k Amp
  • KCA 1/0 Power Amplifier Installation Kit
  • 220 Amp Alt
  • XS Power 12V D925 AGM Battery
  • Stinger Volt Gauge
  • Rockford Fosgate RCAs
  • Box built from birch. Probably tuned to 32 Hz
  • 0 gauge wiring for extra battery
  • Dynamat
“I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.”
Al McGuire
“The only mystery in life is why the kamikaze pilots wore helmets”
Al McGuire
remember this always
Close only counts in horseshoes and hand grenades
i don't know much about the specs and stuff but I'm having that problem right now but its cause my amp is cutting off, because of the fact I'm draining the powersupply so fast
4 15'' Big Perm Subs in a Custom Built Box.
4 Kenwood Excelerion Mids.
1 RockFordFosgate T4000.Bd
1 Alpine 500w.
Alternator: Dual Alternators 1 stock- 1 300amp 180 at idle alternator.
Batterys: 4- 1 for my engine, 3 yellow tops
Check Out My YouTube
Add Me on MySpace
do u think my cap will help
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
what should i do? is my amp gone
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
when you turn your car on does the lights on the amp still light up, if they light up i think it the amp should work, other then that my problem with my system is that my alternator is stock and I need a total of 250w alternator, I'm not sure on your powerage but mine is poor right now, caps help but only to a certian extent.
1 Alpine 500w.
Add Me on MySpace
all stock power my amp lights up fine. i think its my gain. what should my lpf and hpf be at? bass boost? gain? my amp is a ma hk1398
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
tomm i will redo everything. i just realized i made a noob move i turned my gain up reaaaally high damn im an idiot any ideas for amp settings on 2 15s?
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
  • Who's Online   0 Members, 0 Anonymous, 2606 Guests (See full list)
