I have bracing cut i have just not put it in yet. Thats tommrow morning
DC.jpgDC POWER
Well shipping was fast but the bit must have be defective (or just crap). the guys fedback looks good so i did not think the bits would be bad.
Well anyways i got the port cut out but the top of the port is not pretty :( fucking pissed
Im going to try to pretty is up before it goes in the truck ...
Hello Stephen,
I was away for the weekend today and I just got back. I am really sorry about the trouble you had. There were a few of the solid carbide flush trim bits with this issue. We worked on it and I though we corrected the problem. I can send you out a new one and I will also send you another free bit since it messed you up. Please send me the item # so I can get your shipping info.
Once again, I am very sorry.
Regards,
Jonathan
:give_rose:
Posted Image
:censored:
Posted Image
Posted Image
Posted Image
Posted Image
DC.jpgDC POWER
:ph34r:
Posted Image
DC.jpgDC POWER
i still think the very top of the box is going to flex bad
R.I.P!
(Nov-29-2009)
92 explorer
current build
double layering the top would be worth considering, that or some All thread :D
-Drew
uhoh_45 said:
or if you dont care bout looks just throw some 2x4s on the top the box to stiffen er up
R.I.P!
(Nov-29-2009)
92 explorer
current build
Well i think i will put some 2x4 up top
Part i did not show is what the box is sitting on is a sheet of 3/4 and its bolted to the factory seatbelt bolts since there is not seat there anymore :D
DC.jpgDC POWER
