Question About Port Area
reinke
right now my box is 3.1 cubes after all displacement tuned to 38 or 40 i cant remember with 36 sq. inches of port. when i build my new box for 2 15 i want to have 6.2 cubes tuned to 38 or 40. but, do i just double the port area or leave it at 36.
----reference's----
meade916
dude thats too smalllllll!!!! 3.1 cubes = 5356.8 sq inches so with 36 sq in of port thats about 6.7% port diff... try to get that around 10 by using about 50-55 sq in of port like i told ya before... what did jake tell you i dont know what the hell im talking about agian
JVC AVX-2
Audiocontrol EQX
(2) 12" Audiopulse Revo
Planed Audio P2250 D @ .5 ohm
it is not too small. it works perfect for a winter box. i am a hell of alot louder than my 4 12's. what should i do for port area with 2 15's 100-110.
----reference's----
meade916
Harley, keep it exactly where you have it. Right now where you're at you have 12sqin per cuft. That's about as perfect as it gets imo. Just double the enclosure size and double the port area. I would however use aeroports for your next build. Three 4" aeros per sub will work out perfect for your setup. It may be kind of hard to get 6 4" aero's on the side of your box, but if that's the case you may have to fire them up. You will be at least a db louder with aeros over a slot. Right now how your box sits it is almost the same as mine. I have 4 total cuft with 50.24sqin of port. That comes out to be 12.56sqin per cuft. You have 11.61sqin per cuft. You'll be absolutely fine where your at. LISTEN TO JAKE WHEN HE TELLS YOU SOMETHING!!!!!
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
well if i should listen to jake, then i guess me and him are going to be build a 4th order bandpass in there. i sent you a pm with my test results. THEY SUCKED
----reference's----
meade916
  • Who's Online   0 Members, 0 Anonymous, 5726 Guests (See full list)
