Latest Build!..... S-10 Blazer -- Complete Apr 24 --
i love the way you did that wire, how does it work, i mean attatch to the battery, im not familiar with those stinger battery terminals
basically im looking for something very similar with a round 0 gauge input on one end and then a piece of bar for 3-4 ring terminals on each end, something similar to what you have done :)
Well, those stinger terminals have dual ring terminal connections underneath, so just trim a piece of aluminum or copper bar down to rest nicely where a ring terminal should go, drill and countersink the bar for the allen screw to go through, add some loctite, and there is a little attached buss bar. Pretty simple, and super effective.
Check out StoneSounds to see my recent builds.Or look at the Flying White Facebook Page!
thanks man :) ill have to try that soon
My F-150 Build
GET ON THE BANDWAGON
what if they tried messing with the amps when the subs werent louder :ehh: hahah jk :pardon:
So, moved on to the interior of the truck......again.......pulled everything else out, carpet, console, tons of random wiring....
Built a little house (yeah!!! building a house inside a truck that's built like a house!!!!!!!!!)
Posted Image
Posted Image
Put carpet on the house....
Posted Image
Put a pair of these guys on the house....sexy!
Posted Image
Posted Image
Posted Image
Added fuses
Posted Image
Put most of the interior back together... Carpet, kicks, seatbelts, b-pillar trim.. starting to look like a minitruck again.
Posted Image
Posted Image
Posted Image
Slaved the deck in for a minute to make sure everything worked....... Sounds nice, even without the port installed (40hz tuning)
sooo sexy cant wait for it to be complete
R.I.P!
(Nov-29-2009)
92 explorer
current build
wow!!!!!!!!!!!!!!!!!!!!!!!!!! Pat almost there then you can have your life back :friends: :friends: :friends: :friends: or at least your DRIVEWAY :clapping: :clapping: :clapping: :clapping: :clapping: :clapping:
Sickest blazer EVER.... Great work Pat!
Passport Build Here
Alarm: Prestige APS997A 2-Way/Remote Start
HeadUnit: Pioneer DEH-P6000UB
Front Battery: Yellowtop Optima D34/78
Back Battery: 2x C&D Technologies High Rate Series UPS12-475FR 134AH
Subs: 2x DC Lv4XL 18's
Amps: 2x Sundown Saz1500's Strapped
Box: 12Cubes 33hz 185sqin Port(15.4sqin per cube)
Pillars: AudioBahn AS31Q
Front Doors: Clif Designs TX40.5
Back Doors: Clif Designs CD50.4C
Rear Speakers: Clif Designs TX46.5
Front/Rear Amp: Kicker ZX350.4
Back/Pillars Amp: Kicker ZX200.2(Looking for another zx350.4)
Electrical: 1/0 Scorpion Wire 2 Runs Pos and 2Runs Ground, Knu 1/0 Flex Running to Amps ect, Big 3, JL 8Ga For Speaker Wire, Knu Karma RCA's, Scorpion Volt Meter
Deadener: 100 sqft Sound Destroyer Mat And SECOND SKIN Damplifier Pro Door Pack
YEAH!!! It's coming soon...... MAY 10th!!! - - - --- -- - - - - - - -
:air_kiss:
Looks like it is going to hurt.
Thanks fellers... It's been a long good road so far, glad to hear the comments from everybody!
