so that one has 2-10s sharing the same line? is it more peaky, or musical?
from the outside, about 40ft away, it was sounding good
just one 10 in that box. plays pretty flat from 30-50, peaks at 41 in the car but 30 and 50 are oly about 3-5 db behind and 20hz is 8 db behind
http://www.stevemeadedesigns.com/board/ind...showtopic=29213 "sleeper build"
(1) DC AUDIO Level4XL 10
(2) PowermasterD2700 batteries
ALL FOR SALE
TEAM DC AUDIO
TEAM DIRTFLOORPOOR
I need to build somethin now
a couple of different 10" tlines that i built ended up just over 7 cubes each, amazing range and sq for the cone area. runs about 50% of the subs rec. rms well
do you have the plans/ cut sheets for these? I am a retard at figuring them out my self, but I can build like a mofo.
x2. i have some 10"ers layong around i want to do this with. but i have no t/s on them.
Edited by reinke
----reference's----
meade916
i always build mine like this....find your fs of the sub....start your tline at atleast 25% more square inches of area than the surface area of your driver....the end of the line will be the exact surface area of the driver(example...if a 10" speaker is 78.5 sq then add 25%min= 100sq") that is where the sub is placed and then the port...(the end of the line will be 78.5) now for the length of the line, use 25% of the fs so if yout sub has a 32hz resonant freq then make the line 8feet long. gradually taper the line down to the end with the last 20 inches the same as the port opening, for sq, pack in long strand wool at 16oz per cube, taper down till the last 18 inches. for spl leave empty.....pull out or add fiber till you acheive the sound that you want.
Edited by jack
ALL FOR SALE
TEAM DC AUDIO
TEAM DIRTFLOORPOOR
  • Who's Online   0 Members, 0 Anonymous, 1005 Guests (See full list)
