LoudBlazer Posted November 13, 2008 Report Posted November 13, 2008 I love Craigslist. Well i bought a Power Acoustik LT1920 and 4-12" Inifinitys for $40! Its only a temp system till i start getting everything done for SBN 09. Ill get vids as soon as i can! Its not to bad. I bet i have the best bang for the buck ever haha 1997 2 Door Blazer Bagged & Body Dropped SBC/TH350
David Posted November 13, 2008 Report Posted November 13, 2008 build the outside shell as big as you possibly can, build as strong as you can. once you have a big strong shell, calc-out all the space, do it repeatedly until your positive of what you got. then decide on what your doing, IMO this is the best way, cause the shell IMO is the hard part becuase most cars/trucks your gonna have odd angles and all that jazz. take your time, plan it it out right, and you'll only have to build it once.
LoudBlazer Posted November 13, 2008 Author Report Posted November 13, 2008 Ive doen a wall once before and ppl want it back. Im liking the idea on usin a 2x4 on the the sides of the box at an anlge on which the mdf lays on it. isaw the guy from aussie do it with his DD build and it looked liek it worked ver ywell. Im just not sure how many subs i want to run lol. Im think 12-12s? 1997 2 Door Blazer Bagged & Body Dropped SBC/TH350
LoudBlazer Posted November 14, 2008 Author Report Posted November 14, 2008 Well im gonna pass on the wall. I just picker 4 Re Se 12s. Gonna finish my current box thats tuned super low and find a good amp for the 4-12s. I hope to have it done before the LNO show here in orlando before december 6th. 1997 2 Door Blazer Bagged & Body Dropped SBC/TH350
Stephen Posted November 14, 2008 Report Posted November 14, 2008 you change your mind to much you can cook bacon shirtless if you're not a pussy...lol not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be. DC POWER
LoudBlazer Posted November 16, 2008 Author Report Posted November 16, 2008 Well i have changed my mind again and im gonna keep it a secret till SBN 09! 1997 2 Door Blazer Bagged & Body Dropped SBC/TH350
uhoh_45 Posted November 16, 2008 Report Posted November 16, 2008 your dimentions are 30x38x40 is it 30Hx 38Wx 40D or what R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
LoudBlazer Posted November 17, 2008 Author Report Posted November 17, 2008 Yep! I might can go a little longer. Im gonna finish buying the power and subs before i get pics of the build up. Just hope to have it done before SBN09 1997 2 Door Blazer Bagged & Body Dropped SBC/TH350
uhoh_45 Posted November 17, 2008 Report Posted November 17, 2008 buy 2 more 12s and do this 20 cubes before displacement and tuned to 30hz R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
LoudBlazer Posted November 17, 2008 Author Report Posted November 17, 2008 Does look good but calculate 3 12" subs =36" 1.5" of wood i mean i wont have any gap between subs but if its braced right it owuld work. Ill come out and say i was acually thinking 12 but 6 like that would be loud! 1997 2 Door Blazer Bagged & Body Dropped SBC/TH350
