Fi Car Audio
This Is My (Soon To Come) Setup Is It Good Or Not?
SUB:(1) 18'' Fi.BTL (Fully Loaded):D2,Cooling,HiXm Coil,Induct Heat Ring,Daily Option.
AMP:(Two) Hifonics Brutus BXi 2008D (2000 Rms @ 1ohm,Overrated So Maybe 1700 Or 1800 Rms @ 1ohm Total 3600 Rms & Fi.BTL's Are Recommended @ 2000 Rms)
(4) Screws For Terminals (Better Solid Connection No Leaks)
Enclosure:(1) [Ported] 8.6 Cuft. (After Displacemant) Tuned To 32hz. 3/4 MDF
Will That Be Loud?
Also How Deep Would It Get For One Sub With A Enclosure That Big?
For A Lucky Quess Do You Think I'll Hit @ Leats 145db's If Not A Little Over?
P.S:This Is My Budget So Please Dont Ask For Anything More Expensive
I Appreciate You Reading This Message Please Answer :)
Very Very Soon 2 Come???
(1):2002 Chevy Blazer Xtreme (2-dr. with Sunroof)
(4):15'' Orion Hcca's
(1):Stetsom V 14K2D
(6):Kicker PKD1 (Ampkit)
Ported:14 Cuft. (After all displacements) Tuned to 34hz. 3/4 MDF
(8):Screws for terminals (Better solid connection no leaks)
(1):Dynamat xtreme license plate kit
(1):Kenwood eXcelon KDC-X492
(3):300amp HO Alternators
(4):Kinetik HC 3800 Batts.
(1)Rockford Fosgate Power T8004 (For Mids & Highs)
(4)Rockford Fosgate Power T162S (Mids & Highs)
(3):Kicker PKD4 Ampkit (For Mids & Highs)
(1):Kinetik HC 1800 (under the hood or yellow top)
(1):Viper 5701 (p/n 5202V) ALARM
Big III will be done (beefing up my electrical system) etc.
Goal:154.9db-159.5db
if youre planning on running that much power to it, drop the box size closer to 6cubes, or else youre gonna get some nice unloading and other things on lower notes, and by "nice" i mean "destructive"
my .02
and it will def get loud and def get low, and depending on the vehicle and other factors (deadening, batteries, chargin system, orientation, etc) 145 is definately possible.
Team DC
For the price your are paying for two of those amps you could just get a Kicker zx2500.1, Rockford t20001bd or t30001bd, sundown saz-3000d, etc.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
Your Probaly Going To Think Im Crazy But What Exactly Do You Mean By "nice unloading and other things on lower notes" and by "nice" i mean "destructive"
Please Here Me Out!!!
(1):Stetsom V 14K2D
The box is too large your sub will unload.... aka voicecoil will slam against the backplate.....aka it will bottom out destructively.
My YouTube Videos
yea, sorry if i was unclear
bad things happen if the box is too large, physical damage mostly.
decrease the size closer to 6 and it should be fine, use a subsonic filter
Team DC
Okay Is It Possible That I Can Run Both Of Those Amps & Still Get A Decent 1 Ohm Load? Im Going To Get Everything Installed Professionally
"Custom Sounds" Maybe. Now I Know Even If One Amp Is Off By A Lil It Will Kill My Sub But Cant The Audio Place Equal Them Out So It Wont Hurt My Sub? One More Thing Since Im Giving It Alot Of Power Will It Still Get As Deep And Loud In A 6 Cuft. Enclosure As It Would've If I Kept The 8.6 Cuft. Enclosure?
P.S:If I Cant Use Both Amps To One Sub Can You Find Me A Amp Thats Just As Good That Puts Out That Same Amount Of Power If Not More? This Was The Total Of The 2 Amps: 638.12 (Shipping Included!)
Edited by lamchop_8
(1):Stetsom V 14K2D
if you make the enclosure around 6 cu ft you can tune to play low notes. yes the audio place can set the gains and all that so you wont kill your sub. as for getting one big amp for around $638, look around bro ........ or look into the AQ2200d ($379 shipped), Hifonics 2608d and many other for around $600 .......
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
I've Just Seen A New Amp Which Amp Is Better
Two Hifonics Brutus BXi 2008d's
http://www.sonicelectronix.com/item_12120_...+BXi+2008D.html
Or One AudioQue 3500D
http://www.audioque.com/aq/AQ3500D.htm
(1):Stetsom V 14K2D
  • Who's Online   0 Members, 0 Anonymous, 2083 Guests (See full list)
