lt1jerome Posted November 21, 2008 Report Share Posted November 21, 2008 I have been reading and reading many threads on this and other audio sites. But I'm confused when people describe their setups and mention multiple runs of O gauge. I have always ran from the battery to a distrabution block to the amps. Can someone shed some light on this for me. Quote Link to comment Share on other sites More sharing options...
Guest Posted November 21, 2008 Report Share Posted November 21, 2008 more runs of 0 gauge lets more power flow from the alternator to the back batteries Quote Link to comment Share on other sites More sharing options...
duct_tape123 Posted November 21, 2008 Report Share Posted November 21, 2008 If you look at the wire you have it has a lot of little strands of wire. That is basically what the multiple runs of wire is doing, lots of little(OK, 1/0 is huge but its the same principle) wires making up one big one, usually connecting to multiple batteries for more power!! Quote Link to comment Share on other sites More sharing options...
Neo_frog Posted November 21, 2008 Report Share Posted November 21, 2008 Basically they mean instead of running just one wire from battery to back, they run MULTIPLE. Once you get to high power applications, it's a neccessity to have tons of 1/0 wire or bigger. Quote Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/ Link to comment Share on other sites More sharing options...
ALPINE408 Posted November 21, 2008 Report Share Posted November 21, 2008 Its like the batt sitting next to the amp when you do multi runs for better çurent and power flow Dont forget to match the runs of power with as many runs of ground Quote Have you ever had your woofers blown? Link to comment Share on other sites More sharing options...
lil_italy773 Posted November 21, 2008 Report Share Posted November 21, 2008 Basically they mean instead of running just one wire from battery to back, they run MULTIPLE. Once you get to high power applications, it's a neccessity to have tons of 1/0 wire or bigger. yes absolutely, 1 run of 0 awg is really only good for 3k rms. ppl with muti amps and need to feed each amp individually or 2 inputs on a amp. muti runs will let more power flow, same as the multi grounds will find the path of least resistances also. Quote Link to comment Share on other sites More sharing options...
Bills Posted November 21, 2008 Report Share Posted November 21, 2008 ok, say i have 2 1/0 runs for +. I was talking to Randy and he said i should pry do a run to chassis ground and then bring it up with the big three. and then a full run for 2 - runs. well. would having 2 chassis grounds a one - run to bat be benifitial? Bills Quote KwB Team DC Audio Midwest captain Link to comment Share on other sites More sharing options...
lil_italy773 Posted November 21, 2008 Report Share Posted November 21, 2008 ok, say i have 2 1/0 runs for +. I was talking to Randy and he said i should pry do a run to chassis ground and then bring it up with the big three. and then a full run for 2 - runs. well. would having 2 chassis grounds a one - run to bat be benifitial?Bills yeah that would be a good idea. when i had my blazer i did that i gronded in the real and up front with the big 3. i only had the rear ground for a whileand finally did a 2 ground run and found that my batts charged .4v higher was charging 14.3v went to 14.6v steady. i did a resistance check with clamp meter and it was showed a pretty big difference. the less resistance the better of course so muti grounds are gonna help Quote Link to comment Share on other sites More sharing options...
Bills Posted November 21, 2008 Report Share Posted November 21, 2008 o, hey man, long time no talk. haha, hows it going? didn't reconize your stuff with the diff avatar. haha Bills Quote KwB Team DC Audio Midwest captain Link to comment Share on other sites More sharing options...
lil_italy773 Posted November 21, 2008 Report Share Posted November 21, 2008 sup man yeah i put my truck on there with a causeway in the back the many in miami. yeah out with the old in with the new. got anymore vids? Quote Link to comment Share on other sites More sharing options...
