This May Sound Like A Dumb Question
Guest DC Power Kyle
Guest KyleCannon
Alright, never really looked into this or put much thought into it. Why do they have 2 channels on the P1000-1bd when its a 1 channel amp? can i use one channel per sub to reach a 1 ohm load if im wiring in parallel? Or would I have to wire on one channel to both subs.... never really understood the concept, and sorry for the dumb question everyone. :rolleyes:
it is actually 1 channel, the amp is internally parallel
the 2 "channels" you're seeing are actually only 1 channel. the + and - s are literally attatched to each otehr in the amp. they do this so if you have 2 subs its easy and clean to hook it up.
so you could use either channel for 1 sub and still get full power.
understand?
~Matthew
1998 Toyota Camry XLE V6 3L
(1) ScyTek Astra 4000RS-2W-1 2-Way Remote Start Alarm
with Shock and Proximity
(1) 20% Tint All Around (Gately Audio)
(1) 250 Amperage HO Alternator
(1) Big 3 Done In 1/0
(2) Kinetik HC2400 Power Cell
(1) Alpine IVA-D106 Receiver
(1) Peripheral Video Bypass Device
(4) Alpine SPS-17C2 Speakers
(1) Alpine KCE-422i iPod Control Interface
(4) Sheets Dynamat Extreme; for speakers
(1) 10 Square Feet Hushmat (Trunk & Rear Deck)
(4) DC Audio Level 4 15" D2 Subwoofer w/ Level 5 Coils
(1) Wall Built By David, Tuned to 32 Hz
(1) Rockford Fosgate T40001bd Amplifier
(1) Stinger 1/0 Wiring (2 runs of + 2 runs of -)
(1) Stinger Volt Meter
I was kind of no help huh? lol
yeah, ^^ all true, same exact terminals, just in parallel blahh blahh
just easier, more flexible sub wiring
Guest KyleCannon
Nah you were Forevr, just wanted to make sure I was understanding correctly, So I could wire each sub parallel to reach 2 ohms a piece then internally it would make it 1 ohm, correct?
Should be. Inside the amp it is just connecting whatever load(s) you give it in parallel. The two sets of speaker terminals are strictly to make things neater and cleaner.
  • Who's Online   0 Members, 0 Anonymous, 741 Guests (See full list)
