Applejack's 15" T-line Vids Up
did that fit behind the second row of seats?
previously known as wenn_du_weinst aka fucking internet coward supreme.  I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
Nice lookin Tline
not lovin the port being cut back
Im sure the sound is amazing tho
not to post dump but here's mine tuned around 28Hz
Posted Image
DC Sound Lab & Rockford Fosgate FTMFW
you could turn it into quarters and put it in a pool. no one suspects a person of doin drugs with a pool full of quarters
Between his box and gangsta lean, You gotta be a legless midget to sit back there
The enclosure actually sits right at the piviot of the seat hinges and his amp and battery are sitting on the folded down seats. This is kinda for 2 reasons really. 1 to give the bitch some room to breathe and produce and so he can get used to not using the back seats as they wont be around much longer, but thats all i'm saying about that part until a later date.
As far as those of you that arent digging the port cut back, i originally designed this to be tuned at 30.5, but being Apple is a bit of a metal head the tuning was moved up to 32 to help with it reproducing double bass kicks a little stronger. That being the case the port had to be 5 inches shorter and being this is a tapered design it would have been a severe whore to keep the line length where it needed to be to tune to 32 and make it a squared off even Enclosure. Besides, with it being cut back a hair, it gave it a little more room to breathe and produce a little more in relation with cabin gain rather than being choked off closer to the rear hatch door....
Daily Driver 1999 Kia Sephia
Kenwood DNX-893s
Audison Bit One Processor
2 Dat 4.125's
Sundown Audio SCV-6k
Hertz hsk-165xl's Mids running active        Focal V30 Series Tweeters running active
Sundown Sa-8 v1's in the doors
2 Sundown Zv5 12's
Lots of Hushmat
Big 3+ and 3 + & 3- runs of Trystar 2/0
2 Dc Power Engineering 320 HP Alts
2017 Comp Vehicle
2006 Toyota 4 Runner
Kenwood Excelon DNX-893s        Audison Bit One HD DSP
4 Sundown Sa 6.5v2 Component Sets
Focal Access 6.5 2 ways
Sundown Audio Sax-50.4        Sundown Audio Sax-100.4
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
2 Northstar asmagm 480's
2 Dual 1 Sundown Nightshade v3 12's
2 Sundown SCV-7500's
All SMD Fuse Holders
Shitload Of Sundown 1/0
120 sq ft Second Skin Damp Pro
No, Its Not A Burp Truck!!!!
2016 Season 3rd place in Xtreme 1 At Finals
2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations)
2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL
David said:
audio is a lifestyle, not a hobby
newls1
I cant read a tape to save my life... 1/2's are ok, but other marks confuse me
kingsuv
only men who cant read a tape, take it in the ass
kingsuv
you sir, get a pink hard hat on jobsites
ok I see I was trying to figure out how you got a t-line for a 15 to fit in a blazer like that
I have to say it Chris!!!!! This thing is f'n ridiculous!!!!!! I run 2 15's with 1000watts on each in a cute little sunfire, and this thing on only 600 or 700 watts in a blazer, was putting my system down. Not only was it dropping lower, it was tighter, and way more ruthless. Props to chris, can't say it enough. I can't say it was insanely louder than mine, but it was much more ruthless with the air movement. 1 15 making the ceiling of the blazer bow like mad!!!!! body, roof, interior, everything was just goin crazy. I am blown away by the performance of the enclosure. Plus the fact that the speaker had issues makes it that much more impressive. PROPS!!!!!!!!!!!!!!
Loud as f*ck, and sounds good doing it.
Team built from here on out!!!!
BIG things to come.........
Missing link is the shite!!!
You, sir, have a Private Message.
did you have more power and hand to see what the max you could run into this box I'm guessing 700 watts is pretty close to the max if that's a regular lvl 4
there is actually more power that can be had out of the amp that is in the blazer currently, however with the current state the sub is in, it is actually seeing a higher resistance that it normally would running in parallel. when the sub was pulled out of the regular ole ebay ported prefab he had it in and had been sitting around a bit, eaglescorpio noticed it had a broken tensil lead so we had to solder to that broken tensil with some 12 gauge awg wire and use it as the actual negative terminal. what should be 1 ohm that amp is seing b4 box rise is now 3-3.5 ohms. Needless to say, the bitch needs a recone
Kenwood DNX-893s
2 Dat 4.125's
2 Sundown Zv5 12's
Lots of Hushmat
2017 Comp Vehicle
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
newls1
kingsuv
kingsuv
Dang, this is about exactly what I have plans to do. Just to help out on my calculations, any idea what the total size of the box is?
Ill probably be building a t-line for a pos 12 here pretty soon unless loganberry will sell me one of his subs....
Anyways, definitely get some video up... im anxious.
