Alright, I was doing a small system install for my friend and have run into some issues I cannot figure out.
The 4-gauge positive wire is going from the amp to the positive jump post of the battery.
80 amp in-line fuse for the positive wire.
30x2 fuse on the power akoustik amp.
The ground cable is hooked to a bolt on the frame.
RCA and Turn-on wire properly hooked up to deck.
Speaker wire to sub.
THE PROBLEM: When i put the in-line fuse in, (keys not even in car) with all the wires hooked up to the amp, the 2 fuses in the amp pop.
When i put the in-line fuse in with JUST THE POWER WIRE there is no reaction until i touch the ground to the part on the amp, then the fuses pop.
I believe that the problem is the ground wire, but am not positive, I have tried multiple spots and the same thing happens.
Could it be that the 80 amp in-line fuse is too much to put in there compared to the 30x2 fuses in the amp?
Help would be greatly appreciated.
EDIT: I know what you mean actually, I'm going to go check all of the wires right now for any scrapes or openings.
Edited by Dank
which.. the power or ground
they are both fresh out of the box so i don't see why i'd have to replace. but if i have to i will
Edited by Dank
try taking off the - on the car battery, then hook everything up, then put the - terminal back on the battery.
Edited by Krannyman92
