Install Torsion Keyway In 02 Explorer Sport
hey everyone ive been on here for a bit mostly reading all the cool stuff going on...just wondering what a good shop in the east bay area is, as i have 2 inch drop keyways for the front of my 2002 ford explorer sport, it will need the camber caster adjuster for the car also and be aligned. So any shops you reccomend?
DCAUDIO
BALLS DEEP
  • 3 weeks later...
big O?
:rofl:
GL man- see you tomorrow morning
-Drew
uhoh_45 said:
big o wont touch it, something about explorers and rollovers :P
i usually go to roger kraus racing but their in like fuckin castro valley and thats helllaaaa far and i gotta sit around there all day while they work on it...looking for somewhere local and good, do my keyways, front and rear sway bars, camber caster and alignment....sittin low in the rear like a lincoln aint my bag of tea :|
DCAUDIO
BALLS DEEP
  • 1 year later...
torsion key unloading tool
patience, PB blaster, and maybe a torch and you can do it in your garage
text me if you run into any problems
Wouldnt be thehoe92 without teh purple
im doing it at the shop i just have never removed some, im going to get a big ass gear puller and give it a go...how do i unload the bar? remove the bolts and just let the tires hang should do the trick?
im not even sure these torsion keyways will lower it all that much shoot, they look identical to stock. we shall see. :drinks:
DCAUDIO
BALLS DEEP
they should look identical to stock.. they are just re-indexed where the bolt is situated
a 2/3 gear puller will also work thats what I used just take the 3rd claw off and line the 2 up on each opposite end
take the torsion bolt out and let the torsion key rest on the spacer
hook the gear puller on both sides of the crossmember and crank the bolt in the notch
make sure it is on the crossmember good because this is where accidents happen
take the correct sized wrench and start turning the gear puller until you can get the stock key off of the spacer then loosen the gear puller SLOWLY as there is still tension on the torsion bar and then the stock key should just be hanging on the end pull it off put the new one on and reverse the steps
tires don't even have to hang I did mine with the tires still on the ground
  • Who's Online   0 Members, 0 Anonymous, 1461 Guests (See full list)
