Mellow18 Posted November 29, 2008 Report Posted November 29, 2008 (edited) well i was driving and my amp just cuts off..i didnt hear no wierd noises and it didnt smell burnt..and there was no smoke... no power or protection light turns on..wat does this mean? no wires were out or loose. no fuses broke. RCA are fine.i tried connecting the RCA from my highs to my bass.switched from the head unit as well.still nothing the amp for my highs still turns on (protection light turns on (red) then shortly the power light turns on (blue) dont know if thats normal. they are connected to the same ground/power/remote i looked in the back of my head unit and the remote is connected to the (blue) wire with a (white) stripe.the blue wire with a white stripe has (2) blue remote wires connected to it..is that normal? ive tried to reconnect the remote..and unhook the speaker wires.. disconnected everything and reconnected and still nothing.. Edited November 29, 2008 by Mellow18 Quote 2001 Black Monte Carlo SS chrome 20'' (1) Alpine i-9881 deck-ipod- (2) DC lvl 4XL 18''s-Walled- (1) DAT Hellfire - 2500.1-fused- (1) D3400 XS Power battery-fused- (2) CDT 6.5 comp (X) pioneer 6x9 set (1) RF T-400.4 (1) DC POWER ALT INSTALLED BY ROB FTW,Big3 (1) Viper 5901 Alarm + killer yorkies and chihuahas [EdgarCervantes] 4:31 pm: im in my room and out of nowere i hear bass im like oh shit sombody has bass in this city, i look out the window and its my mom bumping Gorilla Zoe
Boon Posted November 29, 2008 Report Posted November 29, 2008 Does the sub amp have a seperate fuse? Check the fuses individually with a multimeter - they can be bad and still look fine. Otherwise it sounds like the amp may be stuffed ;/ Quote 10.x volts fo' life!
Mellow18 Posted November 29, 2008 Author Report Posted November 29, 2008 Does the sub amp have a seperate fuse? Check the fuses individually with a multimeter - they can be bad and still look fine.Otherwise it sounds like the amp may be stuffed ;/ No,the amp doesnt have a fuse on it =( what do you mean stuffed? Quote 2001 Black Monte Carlo SS chrome 20'' (1) Alpine i-9881 deck-ipod- (2) DC lvl 4XL 18''s-Walled- (1) DAT Hellfire - 2500.1-fused- (1) D3400 XS Power battery-fused- (2) CDT 6.5 comp (X) pioneer 6x9 set (1) RF T-400.4 (1) DC POWER ALT INSTALLED BY ROB FTW,Big3 (1) Viper 5901 Alarm + killer yorkies and chihuahas [EdgarCervantes] 4:31 pm: im in my room and out of nowere i hear bass im like oh shit sombody has bass in this city, i look out the window and its my mom bumping Gorilla Zoe
andym85 Posted November 29, 2008 Report Posted November 29, 2008 i would check all the fuses with a dmm... then maybe jump the remote wire straight to the battery to make sure it isnt loose in the headunit's wiring harness somewhere. then double check the power and ground wire... if all that checks out and you still arent gettin power..then u could be screwed. Quote i likes me some audio stuff...
Mellow18 Posted November 29, 2008 Author Report Posted November 29, 2008 (edited) i would check all the fuses with a dmm...then maybe jump the remote wire straight to the battery to make sure it isnt loose in the headunit's wiring harness somewhere. then double check the power and ground wire... if all that checks out and you still arent gettin power..then u could be screwed. well a few minutes ago i jumped the remote and the other amp i use for my highs is running off the same ground/power/remote and it still works ! i did not abuse the amp. and it was set right. i was running 3 rockford fosgate 12's on it.. 2 were DVC punch power 1000 RMS 2000 maxx power and 1 was punch Hx2 250-500rms and 1000 watts max power all 4 ohms.. the Amp is Precision Power 2600.2 Watts power class.. i also have a 2400.2 power class precision power which is not connected to the car. because i dont know if it will happen again..i bought each amp for 150$$ each from craigslist. Edited November 29, 2008 by Mellow18 Quote 2001 Black Monte Carlo SS chrome 20'' (1) Alpine i-9881 deck-ipod- (2) DC lvl 4XL 18''s-Walled- (1) DAT Hellfire - 2500.1-fused- (1) D3400 XS Power battery-fused- (2) CDT 6.5 comp (X) pioneer 6x9 set (1) RF T-400.4 (1) DC POWER ALT INSTALLED BY ROB FTW,Big3 (1) Viper 5901 Alarm + killer yorkies and chihuahas [EdgarCervantes] 4:31 pm: im in my room and out of nowere i hear bass im like oh shit sombody has bass in this city, i look out the window and its my mom bumping Gorilla Zoe
goingdef Posted November 30, 2008 Report Posted November 30, 2008 all three speakers on the same amp if so I'm amazed the lower end one has not cooked Quote
Boon Posted November 30, 2008 Report Posted November 30, 2008 How did you have the subs wired? If they were all paralleled then that's a 0.8 ohm load. And if the amp was bridged, being a 2 channel, it would be seeing 0.4 ohms per channel. I would call that abusing the amp, and I would say inside it's gonna be smokey smokey MOSFET. Quote 10.x volts fo' life!
Mellow18 Posted November 30, 2008 Author Report Posted November 30, 2008 (edited) How did you have the subs wired? If they were all paralleled then that's a 0.8 ohm load. And if the amp was bridged, being a 2 channel, it would be seeing 0.4 ohms per channel. I would call that abusing the amp, and I would say inside it's gonna be smokey smokey MOSFET. this was my mistake... i got the wiring diagram from rockford fosgate wiring wizard. well i still have the 2400.2 PPI 500 rms..and im unsure of how to use it.. 3 sub or 2 sub..and how they need to be wired.. well ill let the experts on here give their opinions before i fuck something up.. Edited December 1, 2008 by Mellow18 Quote 2001 Black Monte Carlo SS chrome 20'' (1) Alpine i-9881 deck-ipod- (2) DC lvl 4XL 18''s-Walled- (1) DAT Hellfire - 2500.1-fused- (1) D3400 XS Power battery-fused- (2) CDT 6.5 comp (X) pioneer 6x9 set (1) RF T-400.4 (1) DC POWER ALT INSTALLED BY ROB FTW,Big3 (1) Viper 5901 Alarm + killer yorkies and chihuahas [EdgarCervantes] 4:31 pm: im in my room and out of nowere i hear bass im like oh shit sombody has bass in this city, i look out the window and its my mom bumping Gorilla Zoe
Boon Posted December 1, 2008 Report Posted December 1, 2008 Can you post which diagram you used? Or were they all just in parallel? Quote 10.x volts fo' life!
Mellow18 Posted December 1, 2008 Author Report Posted December 1, 2008 Can you post which diagram you used? Or were they all just in parallel? http://www.rockfordfosgate.com/rftech/woof...mp;woofer_imp=4 i believe and i was playing hypnotized and it made my car battery volts go down while the car was on Quote 2001 Black Monte Carlo SS chrome 20'' (1) Alpine i-9881 deck-ipod- (2) DC lvl 4XL 18''s-Walled- (1) DAT Hellfire - 2500.1-fused- (1) D3400 XS Power battery-fused- (2) CDT 6.5 comp (X) pioneer 6x9 set (1) RF T-400.4 (1) DC POWER ALT INSTALLED BY ROB FTW,Big3 (1) Viper 5901 Alarm + killer yorkies and chihuahas [EdgarCervantes] 4:31 pm: im in my room and out of nowere i hear bass im like oh shit sombody has bass in this city, i look out the window and its my mom bumping Gorilla Zoe
