If it was like that then maybe it wasn't impedance... but check.
maybe i should just have the 2 subs in parallel instead of 3?
im new to car audio... i used to have 1 shit amp to each sub for a long time and no problems..accept for the shitty quality =)
so it wasnt that i wired wrong...or that i bridged?
Edited by Mellow18
2001 Black Monte Carlo SS chrome 20''
(1) Alpine i-9881 deck-ipod-
(2) DC lvl 4XL 18''s-Walled-
(1) DAT Hellfire - 2500.1-fused-
(1) D3400 XS Power battery-fused-
(2) CDT 6.5 comp
(X) pioneer 6x9 set
(1) RF T-400.4
(1) DC POWER ALT INSTALLED BY ROB FTW,Big3
(1) Viper 5901 Alarm + killer yorkies and chihuahas
[EdgarCervantes] 4:31 pm: im in my room and out of nowere i hear bass im like oh shit sombody has
bass in this city, i look out the window and its my mom bumping Gorilla Zoe
We need to know exactly how you wired it.
If you have 2 subs in parallel your amp will still explode. That's 1 ohm, bridging gives you half an ohm per channel and lots of bad smelling smoke. Your amps can only take 2 ohms per channel or 4 ohms when bridged.
10.x volts fo' life!
i wired all 3 like in the parallel diagram.
but i took out 1 sub and now theres 2 subs parallel
(2) CDT 6.5 comp
(X) pioneer 6x9 set
(1) RF T-400.4
this is how i have the sub wired
http://www.rockfordfosgate.com/rftech/woof...p;woofer_imp=4#
what if i wired the subs this way?would it be too much for the amp?
http://www.rockfordfosgate.com/rftech/woof...e&amp_imp=6
(2) CDT 6.5 comp
(X) pioneer 6x9 set
(1) RF T-400.4
Wire like option #2. 4 ohms bridged should work good, just under powered big time!
EDIT: forgot link.
http://www.rockfordfosgate.com/rftech/woof...mp;woofer_imp=4
thats how i have it and it is underpowered...
do you think i should add a 3rd sub and wire all 3 subs as in that diagram
Option 2.
http://www.rockfordfosgate.com/rftech/woof...e&amp_imp=5
(2) CDT 6.5 comp
(X) pioneer 6x9 set
(1) RF T-400.4
you would lose power actually if you wired it at 3 ohms, but not alot
the 3 speaker 2.67 ohm load worked well on the lower amp untill i put the bigger amp in and the amp messed up.. some one tells me that the bigger amp looked like its been wet in the past and that it is dirty inside.
i had the speakers set up the same way on the smaller amp ((2400.2)) for a while n it did not mess up....
(2) CDT 6.5 comp
(X) pioneer 6x9 set
(1) RF T-400.4
  • Who's Online   0 Members, 0 Anonymous, 813 Guests (See full list)
