Crump Posted December 2, 2008 Report Posted December 2, 2008 I have seen Efficiency around the sites, For Example the Rockford Fosgate T-1500 Amp with 68% Efficiency at one ohm. Is the the % of watts that actually gets to the sub or what is it? Team gg Team doa Installs I have doneMy 2010 Rebuild 144 db so far....2 DC xl 10s Firing into cabin on a RF 25002 12" AQ HD's powered by a Saz 2k + Lots o Mids+Highs
Eskii Posted December 2, 2008 Report Posted December 2, 2008 It is the percentage of the total power drawn from the electrical system of your car, which is powering the driver. ie a T1500 roughly puts out ~1700W, therefore the draw from your electricals is ~2500W (68% efficiency) Divide by you're average system voltage and you have current draw Bingo Bango! Previous: 1988 Nissan Patrol Rockford T800.4 Rockford T1 15 (sealed) Rockford 6.5 Components Current: 1997 Jeep Wrangler Build goals... 1x RF P300.2 4x Hertz HCX165's Built Completes Alpine 9886 Headunit RF P300.2 RF P500-1bd 2x RF P2-D2 8" Subs, 1.3 cubes @39.5Hz 4x Hertz HCX130's Current comment... Satisfied for the moment, focusing on performance upgrades
Crump Posted December 2, 2008 Author Report Posted December 2, 2008 It is the percentage of the total power drawn from the electrical system of your car, which is powering the driver.ie a T1500 roughly puts out ~1700W, therefore the draw from your electricals is ~2500W (68% efficiency) Divide by you're average system voltage and you have current draw Bingo Bango! So it is putting out 1500 Watts Rms? So if i wire to 1 ohm with 2 1 ohm Fi SSds @ 800 watts rms they will both get 750 watts? Team gg Team doa Installs I have doneMy 2010 Rebuild 144 db so far....2 DC xl 10s Firing into cabin on a RF 25002 12" AQ HD's powered by a Saz 2k + Lots o Mids+Highs
Boon Posted December 2, 2008 Report Posted December 2, 2008 Correct except for one part. 1 ohm Fi SSDs? Only works if they're dual voice coil. I don't know if the SSD comes in SVC but if you get 2 SVC 1 ohm subs you're boned. (or 2 2 ohm DVC subs) 10.x volts fo' life!
Crump Posted December 2, 2008 Author Report Posted December 2, 2008 Correct except for one part. 1 ohm Fi SSDs? Only works if they're dual voice coil. I don't know if the SSD comes in SVC but if you get 2 SVC 1 ohm subs you're boned. (or 2 2 ohm DVC subs) yeah they are DVC so thats what i get then they will be powered ok? (they are 800 Rms, and they will be getting 750 rms?) Team gg Team doa Installs I have doneMy 2010 Rebuild 144 db so far....2 DC xl 10s Firing into cabin on a RF 25002 12" AQ HD's powered by a Saz 2k + Lots o Mids+Highs
Boon Posted December 3, 2008 Report Posted December 3, 2008 yeah they are DVC so thats what i get then they will be powered ok? (they are 800 Rms, and they will be getting 750 rms?) Yup they'll be fine like that. 10.x volts fo' life!
