Bedliner kit FTW
I always try and use some rhino liner spray at least when doing some kind of paint on my boxes, or builds
Alright, things have been hectic for me at home so progress is slow.
I put a new EGR valve on my engine and it solved my codes and idling problem (for those that helped me with that) so I was able to reassemble under the hood and move the car around.
I bought some rubber boots and cut em up to make a bumper/buffer for my buss bar.
Posted Image
Posted Image
Posted Image
Posted Image
And I started working on the exterior amp housing a bit, and gave myself more mounting area for the front face.
Posted Image
Posted Image
Posted Image
Yeah I know it's not much, but it's something. I'll be able to get all my filler and wiring/amp install done this weekend. I might even have it playing!
I'm trying to concentrate on the inside of the clamshell cause I wanna hear it, but I keep running into small issues and I don't know if I should round out the insides.
What do you think? Go through all the trouble? Or just fill it, smooth it out, and call it done?
Need an install? Hit me up.
[email protected]
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
I say wire it up and play then see if its what you wanted..then i would make it look purty
http://www.cardomain.com/ride/3042878
TEAM DEADLY HERTZ
"GET LOUD OR DIE TRYIN"only the loudest will survive.
So I'm back to work on it today and through the weekend. My plan is to have it operational by Sunday night. I'm at work right now so I can't upload pics, but they'll come tonight.
I'm just gonna lay black vinyl on the baffles, build the amp housing, install the new buss bars and batteries, subs amp install, and I should have things running.
Once I hear it and it all functions well, I'll continue the beautification. I have some interesting plans. (Probably been done before though :P )
[email protected]
im with this guy here who cares how pretty it is wire it up seal it up check for leaks or anything then make it look pretty theres no sense in carpeting a piece only to find out its loose or leaks or somthing or the wall sounds like shit
but it all looks good and hoping for vids soon
R.I.P!
(Nov-29-2009)
92 explorer
current build
That's what I'm gonna do. The only thing is, since I do this by myself, it's very hard to mount the subs on the top baffle so I want to make it a one time thing. Nobody here cares for car audio let alone helping me with installs.
EDIT: When I say "here" I mean at home. Not SMD ;)
I'm gonna do as little as possible for making it look good other than the vinyl on the baffles and that's a quick cheap thing I can redo. My goal is to get sound this weekend. And there's not much left for that to happen.
[email protected]
its sunday nite, does it live?
1997 S10 EC
Whats in it
106.9 Sq.ft. Hushmat
DB Elec. 250 amp alt.
HC800&HC1400
MLA Module
Alpine 9886
Knukonceptz wires
Clarion EQS746
poopy Alpine door co-ax's
Change IS Coming
According to east coast time, u have 58 minutes to make it live
1997 S10 EC
Whats in it
HC800&HC1400
MLA Module
Alpine 9886
Knukonceptz wires
Clarion EQS746
Change IS Coming
  • Who's Online   0 Members, 0 Anonymous, 1045 Guests (See full list)
