What will work best.
11 members have voted
  1. 1. box terminals
    • Brass-Threaded Rod
      3
    • Stainless-Threaded Rod
      5
    • Drill a little hole and then seal her up
      3
I recoemnd you resin and fiber first teh drill holes and pull the wires thru then caulk it......
then I will do that. so what do you guys do with connecters in the box? and why dont I get email notification on this site?
Loudness is no substitute for musicianship, and partial deafness is no badge of honor. I was once able to hear this advice.
Build Log>>>
http://www.stevemeadedesigns.com/board/ind...pid=672024&
New Build
Believe in the order
Just use some regular nuts and bolts.
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
i use bolts to however the mose effective way is to drill little holes and run wire from the amps directly to the sub..that will allow the mose juice to flow, it your not gonna do that then your restircting the flow wnyway so almost any regular bolt will suffice....
not entirely true.
the bolts I use have 0/ zero resistance, im not losing anything.
not entirely true.
x2 I tested the resistance on my bolts and it was the same as the bare wire
TDH FTW !!!
not entirely true.
thx for all the input guys... in terms of millimeters what is the thickness you guys use? the guy at the hardware store said 10 mt not sure what this mean. The reason why i like the rod or bolt idea is for easy configuration changes while keeping it clean. most terminals on the market dont really do it for me. you guys mind posting a pic or 2 up of how you have done it?
im going to use some rod for bracing as well, so some pics of that would be appreciated as well.
thx
Build Log>>>
New Build
this was a dry fit but u get the idea... i didnt take a pic after i installed all the washers and nuts tho
1/4-20 steel threaded rod from lowes
brass washers and nuts and wing nuts all work well, o and silicone to seal (as if the washer against the mdf wont)
heres what i did
wing nut-nut-washer-ring terminal-washer-nut-washer-mdf- reverse
works great.. its overkill but whatever
look into just plain ol dowel rods too, doesnt have to be threaded rod for support...
get 1"+ and its just as strong without having to drill holes and seal
Edited by decafcappucino
heres what i did
thx buddy that looks neat. im in singapore atm so cant go down to loewes. what is that part that looks like a "wet spot" silicone, rezin?
Build Log>>>
New Build
silicone... i lube that rod up before i insert it into the mdf hole.... haha :girl_devil:
just keep it off the brass... and if u do make a mess... use sandpaper to scuff the brass back to clean
  • Who's Online   0 Members, 0 Anonymous, 931 Guests (See full list)
