of rca's? Bought a JVC in dash 7" dvd player avx-710...it only has one set of rca's. What can I use to still get front rear and/or sub outs w/o using the speaker wire (unless thats the best way to go)?
Also..how the f do you hook up fiber optics on car stereo for DTS??? haha never seen it before. (been out the game for quite some time)
Thanks to all
10501650_10203332501847103_1859383749711
Blown
Yea, but with only one set of rca's from the deck how can I use the outputs of the amps w/o using a 'y'...use an EQ??
did you not read my post? just use the preouts on the amp/amps to go to other amp/amps
could always get some line out converters and turn your speaker wire into rcas
R.I.P!
(Nov-29-2009)
92 explorer
current build
or just save money and hook it up like i said. hell, youre taking a chance going through your speakers with not getting the correct frequency.
ok, maybe I'm not looking at this right then, but if you have one set of RCA's coming out the deck and it goes into either a mono or 4 channel amp and these amps only have one output, wouldn't you still need a splitter?
deck to mono, mono output to 4 channel...still need a splitter for the 4 channels (unless you want to run it 2 channel, which I don't).
Deck to 4 channel...still the same problem...yes I can output to the mono with no probs, but still not wanting my mids at 2 channel.
This is what I'm trying to get past...Speaker wire also not an option. Which is why I ask if an audio control three.1 or something would be my fix (EQ with line driver) or buy a different deck, but teh wifey would kill me :unknw:
Not being a pain(i hope)..just want my 4 channel as a four channel...then again...I may be looking at it all wrong. mental pictures are > me ( a lot) =D
Blown
  • Who's Online   0 Members, 0 Anonymous, 506 Guests (See full list)
