I have been looking for a thread where someone has a Suburban but they kept the 3rd row seating (I have to keep mine for my kids) I don't want to compete with the 'Burb' but I do want some tunes (2 15's and around 3000 watts) if anyone knows of a thread please point me in the right direction, Thanks
1990 Chevy Suburban (Big Booty Judy)
(4) Sundown Audio Zv5 18's
(1) Sundown Audio Salt 12K
(1) Sundown Audio SAX-100.4
(1) Sundown Audio SAE-50.4
(2) Crossfire ST-1 Tweeters
(2) Obsidian Audio ST-1 tweeters
(4) Sundown Audio Neo Pro v3 6.5's
Saving 2nd Bass
maybe this shoulda went in general audio?
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
It should be fairly easy to do, I had a 'burban with a pair of SE 12's behind the 3rd row and it slammed! It you used all possible area in the back you should be able to get 13-14ft^3 below the window line. I'll dig up some pictures of my set up if I still have them.
I was wondering something very similar. In a suburban is there anyway you could mount the amps under the 2nd row seats and run wires to the back to a set of mounted terminals so you could disconnect and remove the subs and the 3rd row seats if needed?
1996 Mercury Sable Stationwagon
- Infinity Kappa 682.7 cf's front and back
- Alpine Pdx-4.100
- Hifonics Txi 1008D
- Fi 12" Q, ported at 33Hz
- Kicker distribution hardware
- (1) Kicker 4 gauge run
Plans....
- Sound Processor (Rockford 3sixty.2 or MTX)
- Dynamat
- another Fi Q 12
- H/O alternator
- Aftermarket Headunit
- Component set for upfront
Yes, I had my amp under the second row drivers side seat. I just ran the wires to the box, and when I needed to use all of the space I took the fuse out of the power wire and took the sub box out.
i have two 15's in sealed boxes in my 01, i made an amp rack under the sub box that holds my 3 amps, i will try to take some pics and get them on here for you. i did two 3 cubic ft boxes for mine. my subs face the back and i have about 10" in front of them. the sides of the amps all face the back so that i could get to them if i need to adjust. it was a pretty easy set up to do, you just have to make sure that there is enough space for the amps to vent. i used 3/4 mdf on the bottom to mount everything to, then i cut strips out of 3/4 to rais the amps up a bit so i could run wires under them then i made some blocks that were made of like 4 or 5 lyers of 3/4 that went between each amp and along the back so i had a riased surface to mount the top sheet to, then the top sheet of 3/4 that gave me about 1" of airspace above my amps then the boxes are mounted to the top and i am still below the top of the third seat. i hope that makes sense. again i will try to post some pics on here or you can email me and i can send you some. [email protected]
i had to keep my 3rd row, i have 3 boys and a girl on the way, so as much as i wanted to ditch the third row, momma wouldnt let me ;)
d(-__-)b
beer sucks...but i can bring some jose cuervo. Only problem is that it makes me horny and gives me the rams. So unless yall wanna fight and then have some great make up sex i will leave it home.
well i cant figure out how to get pics on here. if anyone can help with that then i will post my pics for you.
i think i got it now
d(-__-)b
  • Who's Online   0 Members, 0 Anonymous, 700 Guests (See full list)
