New T-line
CR Boom
Not criticising (sp) at all. Just a question. You gonna 45 that right angle? You could kerf that corner too if I am looking at it correctly. Correct me if I am wrong.
Loud as f*ck, and sounds good doing it.
Team built from here on out!!!!
BIG things to come.........
Missing link is the shite!!!
I want to, but I will lose my width.. on cad it just didn't look correct so I am going to do it as I build..
2007 Great Wall So Cool
4-12' RE audio MX's
Stetsom 7k2D
6-Batts
3-Mechman 250 amp Rhino's
is that for a 6.5 or 8?
****edit*****sorry, i skipped the part about 2 sheets. must be a scaled down drawing.
2-12'2 at 30 Hz 9.5 feet..
4-12' RE audio MX's
Stetsom 7k2D
6-Batts
I wanted some advise that is why I posted the pic's..... How critical is it to keep the constant width? I was worried about it being big and then small again, will gain about 1.5 inches there...
4-12' RE audio MX's
Stetsom 7k2D
6-Batts
It looks good, but to my eye, it looks like the area is to large, making the quarter wave look short.
Since the whole box is kerfed, might as well kerf that corner in there
As far as 2-12"s, me personally, I would do it as a horn, start off with area of 1-12, end at 2-12s
And since its 2 subs, you will need to have an actual chamber for the 2, so that the pressure wave going in to the line/horn is in phase with both 12s
i have seen people play with the surface area to see what response is recieved by doing this. there is the tutorial on t-lines that is pinned in the "enclosures" section that foreverbumpin started. and foreverbumpin has already responded about the kerf of the initial corner. I don't have alot of experience so to speak but I will ask someone if I can post a pic of the plans for an enclosure that was built completely kerfed. will get at ya.
hope you are using a circular saw to do those kirfs cuz that would be a bitch to do with a table saw. man i need to build a t-line. who wants to design me two t-lines? one for a 10" tc-oem and another for a 15" tc-3k+.
Need any thing chromed? Hit me up!!!
gamer tag: (360)
mEmEnToMoRi64
My Myspace
refs:
from here: RollinSoLow, Derrick824, Ray
from c.a.c.o. : teamsubgopoof, splvictim20, SundownAudioNY
from C.A.J. : Donpisto, spladdict19, CAJunkyard, JBLCAMRY, DasBot (robot underground)
from ca.com: alxmlr789,photocrazy8
I noticed starting off smaller area, ending up larger area you gain the most in the low end
Ive done this time and time again, with the hundred something quarter waves I built, the last 30 or so, I have slowly flared/horned the opening. Its basically a un-calculated horn, kind of like buying a good prefab box, and throwing a few different subs in it, and noticing they all sound good, but can be a little better, but will settle for now type sound
Sometimes, they just come out beyond well expectated
to this point, I never built a t line or horn that did not sound better than ported in my opinion, even when slightly miscalculated
  • Who's Online   0 Members, 0 Anonymous, 4783 Guests (See full list)
