Adding A 2nd Battery What Else Do I Need
-0 guage from front bat to trunk, can it be soldered or do you have to use a battery terminal at the front battery? Right now i have a Post Extender
-I will also have the Big 3 to that battery soldered, a soldered 4 guage running to a distribution block in trunk which runs to two amps?
-And when i do get a 2nd Battery do i have to disconnect both negatives to work on my system?
1) however u can attach it... bolt... bat terminal... so long as its strong with alot of surface contact
2)all u need is ring terminals crimped and soldered on the ends.. or if you have battery terminals they just slid in...
like these bat terms here...click
you can use ring terminals or raw wire.. one of the many things u could use
again... if ur using a distro block and the amps power termnials u wont need to solder anything... its all raw wire held down with allen set screws
3)when connecting an extra batt... connect everything in parallel... if you dont ground the bats, nothing will work
the rear bat should have a ground 18" or as short as possible to reach the frame/chassis metal. front batt should be grounded already using stock grounds which should have been upgraded during big 3
i have 0 gauge from my front battery to my rear battery, ground 10 inches long to massive bolt that i added to the rear chassis, make sure you clean the paint off any painted surfaces that you add the new ground to, or else you will have little or no connection, just take you're time and make sure you have good connections everywhere
Team sundownWESTCOASTSPL.COM we're throwing dbdrag events very soon visit the website for details
and remember to fuse no more than 18 inches after the 1st battery and before the 2nd.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
Thanks man i you just pretty much told me everything i needed to know, so thanks and i will take this and use it
  • Who's Online   0 Members, 0 Anonymous, 991 Guests (See full list)
