Suicidedoors.com is your friend, they used to have a bag and weld-on cup special for s-10s, they still mite
1997 S10 EC
Whats in it
106.9 Sq.ft. Hushmat
DB Elec. 250 amp alt.
HC800&HC1400
MLA Module
Alpine 9886
Knukonceptz wires
Clarion EQS746
poopy Alpine door co-ax's
Change IS Coming
A compressor, air tank, switchbox, pressure gauges should be in there, plenty of other things,
1997 S10 EC
Whats in it
HC800&HC1400
MLA Module
Alpine 9886
Knukonceptz wires
Clarion EQS746
Change IS Coming
the cup set-ups from S.D are BOLT-IN , NOT WELD IN . you should buy a complete kit ( for both front and back ) so you can save some money instead of buying everything seperately . you don't have to do the rear now but do it later , by buying the whole kit - valves ,tank, compressors, air line , switches/switch box , fittings , etc... then get a front setup ( bags , bolt-in cups (don't get floating cups ) the bag fittings ) you can probably save a couple hundred bucks . you asked what it would cost , i assume for the parts , your looking around $1000-$1300 for the parts , that includes almost everything you need for the whole truck besides a 4-link , rear bag brackets , notch , and any crossmember(s) you need for your specific truck ( you will need a new cross member to raise your gas tank ) if you have an extended cab , you will need a new carrier bearing crossmember . any way , you can always buy things piece by piece , you might look into some lightly used stuff , but what ever you do DON'T BUY SHIT FROM CHASSIS TECH / A.I.M / JUSTBAGIT !!!!!!! you will buy a bunch of crap that ain't road worthy and will fail on you !!!!! good luck on your project , hope to hear the progress .......... :good:
I second suicide doors , though I would call them up an tell them what you wanna do .
they will put you together a package at a good price.
alson sign up on s10forum.com , s10f members get a discount.. Though you have to have so many post on s10f .( i think )
