Why The #*@% Wont My Chassis Ground?
how can i get a better ground to my chassis??? my rear battery idles at around 11volts and then drops down insanely when i use my smaller amp (around 1800w) my 3500w amp plays for literally a second then just dies. i swapped the rear batt to the front and it idles around 13.8 so im not sure what the problem is im pretty close to just running another wire up to the front - batt. i tried grounding to the rear seat bracket and that wouldnt work so i drilled a big ass hole into my chassis right next to the rear seat bracket and bolted it down there and it still sucks so what can i do to get a better ground?
If you are having that big of an issue getting a ground run a ground wire all the way to the front battery/engine.
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
x2
Need any thing chromed? Hit me up!!!
gamer tag: (360)
mEmEnToMoRi64
My Myspace
refs:
from here: RollinSoLow, Derrick824, Ray
from c.a.c.o. : teamsubgopoof, splvictim20, SundownAudioNY
from C.A.J. : Donpisto, spladdict19, CAJunkyard, JBLCAMRY, DasBot (robot underground)
from ca.com: alxmlr789,photocrazy8
What vehicle is it?
You might just be super unlucky and the back is a subframe that's only spot welded/glued to the main chassis, possibly even with paint between the parts. Seems unlikely though... I assume you've done all the usual ground preparation stuff like sanding back the paint? Often using factory bolts doesn't work so well because they still have a layer of paint inside the threads.
10.x volts fo' life!
if the rear idles at 11 before using any current then there might be another problem. Just a tip also try and keep your ground centralized to prevent grounding loops
Loudness is no substitute for musicianship, and partial deafness is no badge of honor. I was once able to hear this advice.
Build Log>>>
http://www.stevemeadedesigns.com/board/ind...pid=672024&
New Build
Believe in the order
yeah i sanded the shit out of it i have no clue what the problem is and its driving me nuts. the car is a 98 jeep grand cherokee but right now im just going to run the ground to the front.
  • Who's Online   0 Members, 0 Anonymous, 1231 Guests (See full list)
