i plan on getting an saz-3000d,fully loaded fi btl , 1kinetik 2400, 1 kinetik1400 in the back and a 300 amp alt an i just got a lil extra cash not much like 120 an i was gonna buy the fuses an fuse holders i will need an i dont kno how many i will need though lol i think 3 right 1 16in away from the batt under the hood, one 16in away from the amp and 1 more from 16 in from the back batt??? an i was lookin for amp wiring kits an i was thinkin this is the one i will need right???http://www.knukonceptz.com/productMaster.cfm?Category=Amp%20Installation%20Kits# but they onley give u a choie up to 200a fuse???
any info will be helpful =] thanks
starting fresh, chrysler 300.. no subs amp nothin
I NEED HELP looking to purchase saz-1500d and 15" 1000rms subREFS- feedback/refs.. click!
i'd say if your run from bat to amp is short (very short) then your good with 3
by front bat and back bat on main line
and by front bat on alt line
if your amp wire is long fuse that 2 (i forget if the sd is internal or external fuse, if external then def 4 so you can fuse the amp)
-Drew
uhoh_45 said:
-Drew
i am RELLY srry but im kinda new lol, but can u elaborate a little bit lol an i saw one the sundown site that the amp dosent come with fuses in it??? what fuses will i need to buy for the amp?
srry its hard for me to understand all this lol thanks
Knukonceptz should have some bigger fuses, they just may not be with a kit.
1990 Chevy Suburban (Big Booty Judy)
(4) Sundown Audio Zv5 18's
(1) Sundown Audio Salt 12K
(1) Sundown Audio SAX-100.4
(1) Sundown Audio SAE-50.4
(2) Crossfire ST-1 Tweeters
(2) Obsidian Audio ST-1 tweeters
(4) Sundown Audio Neo Pro v3 6.5's
Saving 2nd Bass
fuses on wire typically protect wire not equipment. The fuses on the amp protect the amp from a surge. BUT on some model amps (the SD) you need to fuse the wire very close to the amp because the amp has no fuses of its own.
so- you should have two runs from the front bat
first to alt second to second bat. both of these wires should be fused as close as possible to the front bat.
the back bat has a run to front bat and run to amp. both of these wires need to be fused. the first between bats as close as possible to bat 2 and the second on the amp run close to the amp.
that way if any of your power wires ground out fuses will pop and save batteries/amps
-Drew
Edited by Noobtastic14
-Drew
oooooooooo thanks you soooo much noobtastic :good: so is that amp wiring kit i showed you good for my setup???so i will need to buy like 4 300a anl fuses an fuse holders?
