jping2007 Posted January 1, 2009 Report Posted January 1, 2009 Hey guys, Long time viewer and thought i would join up...Have a couple questions1) going to be building a wall in my 04 intrepid. any suggestions on what kind to build or how to build it 2)wheres a good site to get a high output alternator....Any help would be appreciated. also what kind of subs shoul i use...i was thinking 4 15's but dont know what to go with yet. 1998 GMC Jimmy *4 15" Kicker CVRs *2 Kole PH1-4000ds on the subs *2 Kole PH4-1400s on the highs Type R 6x9s, 6 1/2s Infinity 4x6s Rockford punch 3 1/2s Soon to be all Rockford punch highs All 0ga wire Big three 3 deep cycle batteries
Neo_frog Posted January 1, 2009 Report Posted January 1, 2009 Heys guys, Long time viewer and thought i would join up...Have a couple questions1) going to be building a wall in my 04 intrepid. any suggestions on what kind to build or how to build it 2)wheres a good site to get a high output alternator....Any help would be appreciated. also what kind of subs shoul i use...i was thinking 4 15's but dont know what to go with yet. Looks can be deceiving. You might have a really hard time fitting four 15s in there. It's possible, but measure some things out before jumping on that plan. You can look at the Manufacturers Section in the forum and find an alt there. There are many to choose from. Unless someone's had an Intrepid, it's hard to tell you what kind of wall to do, but most simple walls are ported with everything firing forward. As far as how to build it, go to the Members Build/Show off section and look at how everybody does their cars. The best way to learn is doing research. EDIT: Welcome to SMD Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
Nate197 Posted January 1, 2009 Report Posted January 1, 2009 Hey guys, Long time viewer and thought i would join up...Have a couple questions1) going to be building a wall in my 04 intrepid. any suggestions on what kind to build or how to build it 2)wheres a good site to get a high output alternator....Any help would be appreciated. also what kind of subs shoul i use...i was thinking 4 15's but dont know what to go with yet. I have had a 250 amp alternator for about two years from excessiveamperage.com
jping2007 Posted January 1, 2009 Author Report Posted January 1, 2009 Looks can be deceiving. You might have a really hard time fitting four 15s in there. It's possible, but measure some things out before jumping on that plan.You can look at the Manufacturers Section in the forum and find an alt there. There are many to choose from. Unless someone's had an Intrepid, it's hard to tell you what kind of wall to do, but most simple walls are ported with everything firing forward. As far as how to build it, go to the Members Build/Show off section and look at how everybody does their cars. The best way to learn is doing research. EDIT: Welcome to SMD i agree with looks can be deceiving . the trunk looked like i could fit two 15's in it but i could only get one. Im going to do a lot of research before i jump into anything. just trying to get some ideas for the wall. kinda new at those. I have had a 250 amp alternator for about two years from excessiveamperage.com cool cool going to see what they offer and give them a call.. Thanks for the info guys. 1998 GMC Jimmy *4 15" Kicker CVRs *2 Kole PH1-4000ds on the subs *2 Kole PH4-1400s on the highs Type R 6x9s, 6 1/2s Infinity 4x6s Rockford punch 3 1/2s Soon to be all Rockford punch highs All 0ga wire Big three 3 deep cycle batteries
David Posted January 1, 2009 Report Posted January 1, 2009 if I can get 4 15's in a Toyota Camry you should be able to get 4 15s in a intrepid which is bigger.
jping2007 Posted January 1, 2009 Author Report Posted January 1, 2009 if I can get 4 15's in a Toyota Camry you should be able to get 4 15s in a intrepid which is bigger. Looks good. 1998 GMC Jimmy *4 15" Kicker CVRs *2 Kole PH1-4000ds on the subs *2 Kole PH4-1400s on the highs Type R 6x9s, 6 1/2s Infinity 4x6s Rockford punch 3 1/2s Soon to be all Rockford punch highs All 0ga wire Big three 3 deep cycle batteries
Neo_frog Posted January 1, 2009 Report Posted January 1, 2009 if I can get 4 15's in a Toyota Camry you should be able to get 4 15s in a intrepid which is bigger. Yeah, but you're David. Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
Brick2560 Posted January 1, 2009 Report Posted January 1, 2009 David.. that wall is Badass to tha max!! "Buy some shit, Build some shit, Bang some shit!" - Dr. DB Joe owns my soul. Refs: Duct_Tape123, Derrick824
