are earthquake amp any good an how much current or amps do each amp. draw r pull PH10000,5000WATTS AN PH2200,2200WATTS POWERHOUSE BRAND NEED HELP what about the current
Edited by gucci
im now running an older PH D3 and that motherfucker CRANKS out some power. its pushing my T2s pretty good. i got a 146.3 outta it.
NoFearX18 said:
trainman0978 said:
also the 2000 watts one is RMS it does 5000 peak on a quick burp. but RMS is 2000.
NoFearX18 said:
Hate to call you out but that's just not true. The PH2200 is 2200w MAX and actually makes 4x100 absolute tops. If that.
The PHD10000 is only good for about 3000wrms, again absolute tops.
Earthquake have a bad habit of rating their amps at 16/18v.
New Earthquake gear is pretty meh really.
10.x volts fo' life!
thats right...you are correct. im thinking of the old powerhouse shredder d2
Edited by Chode69
NoFearX18 said:
trainman0978 said:
i had one for the longest time but mine were teaked just a little the old ph d2 1000 would about 3200 max @ 1 ohm and 15+volts and the ph d2 2k would close to 5k at 1ohm and 14+ish volts and pulled about l50 amps pushing 2k but mine were all comp amps out of a world finals truck so the normals are a little less
lol. but i haven't and i don't plan on it. plus i'd probably miss and hit her belly button or her ear or something. lol.
You mean these amps?
Man I don't remember if I ever clamped them. One thing I will tell you is they don't like to go below 10 volts. I have them down to 1 ohm each with 2 kinetik 2400's (Street C) set up. I strapped them at finals at 1 ohm. My teammate runs them at 16 volts and they wake up nicely. There is also an internal mod you can do that will allow them to drop down to .5ohm strapped. I've ran them for the past two seasons actually might be looking at get rid of them but, I want them all gone so its gonna be hard finding someone who wants all three.
If the topic starter wants I can see if I get these clamped.
Edited by Team Bassick - Kimo
the one i had were ever older they were all black but if you gice em volts there wake up and i thought the d2 were .5 stable not strapped
Edited by fischy fisch
